Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 2nd August 2006, 05:22 PM   #1361
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
AudioSector-chip amp kits, dacs, chassis Send a message via AIM to Peter Daniel
Originally posted by lohk
The review mentioned that the amp is internally hardwired: Peter, did you do that yourself (what a work!) and why no PCB?
Only AMP-1 is hardwired. Monoblocks use gold plated PCBs mounted vertically between input and output connectors.
The early version of AMP-1 below:
To order kits contact me through forum mail.
Old 3rd August 2006, 06:09 PM   #1362
safetyman is offline safetyman  Malaysia
Send a message via AIM to safetyman Send a message via MSN to safetyman Send a message via Yahoo to safetyman
Peter, I have a LM3875 PCB from you and was wondering if I can use a Caddock MK132 20k ohm instead of the recommended 22k as I can't seem to be able to get the 22k values?
An guidance will be most appreciated.
Thanks.
Shehzad
Aleph 3 - Diehard fan
Old 3rd August 2006, 06:21 PM   #1363
All resistor values are not critical: 20K will work fine.
Old 3rd August 2006, 08:14 PM   #1364
SimonKit is offline SimonKit  Netherlands
I found this review of a year ago of the Pre-T1 and I personally think it is makes things more clear to me than the review in Hifi+...
http://www.6moons.com/audioreviews/a...4/pretone.html
And what a beautiful photo's !
Old 4th August 2006, 06:51 PM   #1365
GHM is offline GHM  United States
Default Audio Sector Dac used with an Upsampling DIP
Hello anyone tried this..using the AS DAC with a Upsampler ..like the Monarchy or GW labs?
If not ..you should try it and be flabbergasted at the difference it makes.
I've always enjoyed my AS DAC. Recently I had a chance to try out a Modified Electrocompanient ECD-1. It basically crushed my little AS Dac on all fronts. I was quite dissapointed!
It should have ..it cost at least 10 times as much as I paid for my little AS unit.
I wasn't ready to give up on the little Dac just yet. So I started looking around to see if I could solve some of the differences I heard between it and the ECD-1.
I figured some of what I heard must be the deficiency of my transport. But at the same time this is the same transport I used with the ECD-1. !! Then I remembered looking over the mods for the ECD-1. The modder mentions adding a Superclock 2 to the unit and increasing the signal strength to the Dac itself.
So my thinking was to add something with a more precise clock output and maybe a signal booster. I first purchased the basic Monarchy DIP that doesn't upsample. The improvements was profound!! I couldn't believe this is the same Dac with just a better signal..simply amazing!!
After reading over some reviews I had the itch to try the Upsampling Monarchy with the AS Dac.. Again big improvement. More air, space around instruments. It has a resolution I've only experienced with the Modified ECD-1. It makes every other front end I've owned sound blurred. The tonality of different instruments and their overtones show themselves now more than ever.
Anyone using this Dac with a basic DVD player or CD player..really needs to try this and hear for yourself. I still can't understand why a NON OS DAC sounds so damn good plugged into a upsampling processor.
Can anyone explain too me ...what's going on here?
Old 5th August 2006, 12:30 AM   #1366
r8833 is offline r8833  Canada
I am using a Monarchy DIP with my AS DAC and it sounds amazing
Rich
Old 5th August 2006, 02:32 AM   #1367
Rich
Thanks Rich for the reply. Glad to see there's another person trying this out. I had no idea this Dac was capable of what I hear from it now. It also made me rethink my speakers. I thought they might naturally roll of a bit or be less resolving. When in reality it was the source that was clouding the sound all of this time.
If you get a chance try the 48/96 upsampler with the AS Dac..you'll be impressed once again.
Good listening
Old 5th August 2006, 01:37 PM   #1368
lohk is offline lohk  Europe
lohk's Avatar
Can you explain how a 44.1/48kHz only DAC shall work with an upsampler? I must upsample and downsample again - I wonder what for. The only reasonable application seems to me some reclocking, "signal conditioning" or something like that.
/lohk/
Old 5th August 2006, 01:41 PM   #1369
lohk's Avatar
I searched the Net: The Monarchy DIP is a digital signal conditioner, not an upsampler. Clear about that.
/lohk/
Old 5th August 2006, 03:07 PM   #1370
karma is offline karma  Canada
karma's Avatar
http://stereophile.com/digitalprocessors/339/
http://www.karmaelectronics.org
AudioSector-chip amp kits, dacs, chassisHide this!Advertise here!
