AudioSector-chip amp kits, dacs, chassis - Page 131 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 27th June 2006, 12:45 AM   #1301
karma is offline karma  Canada
karma's Avatar
hmm thats a good idea
Old 30th June 2006, 09:54 AM   #1302
karma's Avatar
peter im sending all my parts and orders out today, i was wondering if i could get the dimensions of the case off of you?
thanks
Old 30th June 2006, 01:23 PM   #1303
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Front panel is 3 x 10, amp is 9" deep. Tanks for parts.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 1st July 2006, 09:24 AM   #1304
hes21 is offline hes21  Australia
Hi Peter,
Can I ask whether your plans for a USB interface will be at the expense of the other connectors? Or will it be possible to rig it up so you can select between USB and Optical/digital?
Hamish
Old 5th July 2006, 08:27 AM   #1305
Default Parts in Vancouver?
Hi I'm building my first 3875 kit from Peter. So far I've got the boards all built. I want to do a full dual monoblok setup.
Does anyone know of a local store in Vancouver where I could get some transformers (toroid or ei), chassy material, wire etc? I am very new to this and don't know where to start looking. I suppose I could go to the phone book, but if someone knows of a really great spot and could pass it on, that would be great.
Thanks a lot!
Old 5th July 2006, 02:37 PM   #1306
es44 is offline es44  Denmark
es44's Avatar
As far as material for cabinet goes, you can take a trip up and down the Frasier river ( landside of course)
I,ve never seen so much aluminum before. It seems everybody builds, and repair ships with it. Even old trawlers get the wood removed above waterline, and built up again in aluminum.
Talk to one of the small repair shops, and try to get a look in their dumpster, a handful of cold beer may be appreciated
Best regards
Ebbe
Old 6th July 2006, 01:58 AM   #1307
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Default Re: Parts in Vancouver?
Thanks a lot!
I'm right across the harbor in victoria if you need a few things i can donate to you.
Jase
Old 6th July 2006, 07:38 AM   #1308
Geek's Avatar
There's main Electronics at 4554 main St., Lee's Electronics a few doors north and don't forget about RP Electronics, tucked a block in behind the Milestone's on the corner of Willingdon and #7.
Old 6th July 2006, 03:54 PM   #1309
Banned
I would not recommend Main Electronics, They are not good.
Old 7th July 2006, 07:11 PM   #1310
Default Thanks
Thanks so much for your replies. At least now I have somewhere to start! I know there must be at least a few good places and people around here to get a start in DIY.
Cheers!
Copyright ©1999-2017 diyAudio
