Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 18th April 2006, 10:40 PM   #1111
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
AudioSector-chip amp kits, dacs, chassis Send a message via AIM to Peter Daniel
Is it green or golden board?
To order kits contact me through forum mail.
Old 18th April 2006, 10:45 PM   #1112
wdavis009 is offline wdavis009  United States
Green board.
Old 18th April 2006, 10:46 PM   #1113
Did you install the jumper?
Old 18th April 2006, 10:51 PM   #1114
Yes, jumper is installed. I should note I've never used the digital out on this CDP. Maybe there is a problem there?
Old 18th April 2006, 11:53 PM   #1115
Check the voltages on all 3 chips in 4 places. It should read: 3 x 5V and 8V (on DAC)
Old 19th April 2006, 01:38 AM   #1116
I have 3 x 5V and 7.45V on DAC.
Old 19th April 2006, 02:10 AM   #1117
It works. Unfortunately, the digital out on my "good" CDP doesn't so I am running it with a cheap Sony DVD player. Thanks for your patience and help Peter.
Wade
Old 19th April 2006, 02:19 AM   #1118
It still seems like the chip is drawing too much current, as normally, the voltage before regulator should be 11-12V and after regulator 8V (on a DAC).
Old 19th April 2006, 02:28 AM   #1119
I noticed that also but wasn't sure if I should be concerned or not.
Old 19th April 2006, 04:58 AM   #1120
It will work, but certainly it's not normal. What is the power of the transformer? It seems like it's not producing enough voltage.
AudioSector-chip amp kits, dacs, chassisHide this!Advertise here!
