| Audio Sector Kits & PC boards from AudioSector |
#1041 |
HI
I just rewierd the power supply in the gainclone . I went to the Brian's page and I look up the gallery . I found a similar gainclone like mine , with two transformer ect . I saw in that gainclone the power supply was hock up diferent way like mine (after the transformer collor code), the guy who put it together he connected the power inside and the graund each side . I talk about the connection before the bridge . Mine was reverse outside the power and inside the graund . So I changed the connection and the amplifier now is much much better . What a impruvment !!!! Until now the sound was like when you listnen music from the next room . It was mudy and with no bass at all . How I said It much better now . Now evrithing is OK just a bit I miss the butom end , tomorrow I will replace the silver wire , hopping for more impruvment . Peter please let me know how you hock up the power supp before the diodas (bridge) There is four connection marked AC1, AC1 - AC2 ,AC2. Now the both power is inside on the AC1-AC2 ,and much better than before . -If I replace the panasonic capacitors to BC it will give audable impruvment or just waste of money??? About the silver wire with the teflone tube ..... I have four diferent tipe of pure silver wire and I listned before I instaled .Of course I instaled the best one and I used about 50-70 hours until now . I spent a lot of money on silver and gold wire . |
#1042 | |
I also use one of Peter's integrates. Bass has never been a problem. I get sub 20 Hz response in my room with the Audio Sector Integrated and Dac. I also use solid core silver speaker wires. There must be something else causing the problem.
#1043 |
I got a premium kit awhile back and just completed an acrylic casing for it. I tried to hook up some smps units i bought for them. However, i am confused as to how to wire them properly. On the smps side, there is V+ and V-, and on the amp board side there is V-, V+ and PG's. I already blew up a chip so i want to try to be cautious. Any advice?
#1044 |
thanks for the tip on the blade peter. my projects have never been better
and it also worked great on the plexyglass no cracks.
http://www.karmaelectronics.info |
#1045 |
cheers
#1046 |
With proper tools, the sky is the limit
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#1047 | ||
The hum you are getting after switching off the sources is probably because the input to the amp is disconnected (floating) and that causes noise (and it's not recommended). Quote:
I like to use 25K pot. I would go with 300VA, 25V transformer, maybe even better 2 x 22V if speaker impedance is below 8 ohms
#1048 | |
If you mean BG caps, there should be an improvement, I posted some observations here: http://www.diyaudio.com/forums/showt...431#post574431 http://www.diyaudio.com/forums/showt...230#post581230
#1049 | |
#1050 |
Thanks Peter
I know how to conect a transformer to the bridge ,but here we have 8 dioda per power supply and for me that new , never met before something like these . Now I conected the +/- inside (in the midle ) in the pc board and outside the two graund . There is a huge diference between the both conection , like totaly diferent amplifier . May be something wrong with some dioda or I dont know . But at least now I can use the amp. Thanks for the help . I will go ower on the power supp. Cheers |
