Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 30th September 2016, 09:51 AM   #11
nlgbo1 is offline nlgbo1  United Kingdom
LM3875 Kit, too much voltage
Originally Posted by AndrewT View Post
You are not measuring DC when attaching probes to the rectifier. You are measuring the average voltage of the rectified sinewave.
You need to add the smoothing capacitor to be able to store the DC voltage and then attach your probes.
Thanks Andrew, that makes sense! For some reason the kit doesn't include the smoothing capacitors. This was mentioned in the manual:
Code:
If we measure approx. +/- 20V (positive will be lower because of LED) we are ready to connect amp boards.
Please note that voltages are much lower than expected beacuse of lack of smoothing caps.
If you have 10uF caps installed on rectifiers board both voltages would exceed 30V DC
Thanks for all your help on this, much appreciated!
geoff.
Old 30th September 2016, 09:52 AM   #12
R.I.P.
It's not a 25Vac transformer. It may be ~22Vac
33Vdc is a bit low, but may be due to mains voltage being different between this latest measurement and your first measurement.
regards Andrew T.
Old 30th September 2016, 12:09 PM   #13
Mark Whitney is offline Mark Whitney  Netherlands
Mark Whitney's Avatar
Hi nlglo1, did you remove the connection between the two secondaries? In the schematic the secondaries are also connected to ground. I am guessing you removed them too.
Photo's will make helping a lot easier.
Regards Mark.
Old 30th September 2016, 01:23 PM   #14
Hi Mark,
There used to be a connection via a 220k resistor from the secondary the ground, but removing this seemed to make no difference to the DC voltages after the rectifier.
Attached is a photo with the grounds still attached.
Old 30th September 2016, 02:05 PM   #15
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
They seem to be showing 33VDC after rectification.
Correct that to: "after rectification and smoothing"
You are missing C1 and C2 filter caps, which will charge to peak value of 25V minus diode loss, so some:
(25*1.4142)- 1.4 .
Do the Math yourself
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 1st October 2016, 08:50 AM   #16
Originally Posted by nlgbo1 View Post
Hi Mark,
The schematic (on page 14-5) shows connections between 10->14 and 11->16 on the transformer. You have connected 10 to one PSU input and 14 to the other input. Best to check that the secondaries are not connected as shown in the schematic.
Regards Mark.
Old 3rd October 2016, 03:04 PM   #17
Ordered some smoothing capacitors, as I do not have any of the right voltage.
If I connect 10->14, I think that would essentially make it more like a centre tapped transformer? In which case, should I be removing the diodes as per this post:
Center tap torroid wiring to peter daniels kit???
geoff.
Old 4th October 2016, 05:49 AM   #18
R.I.P.
Yes.
Retain 4 diodes to mimic the bridge rectifier.
You must not connect a dual bridge rectifier to a centre tapped transformer.
Use a Mains Bulb Tester to power ON every restart until after you have completed your last modification. It will prevent you blowing up your project if you make a wiring mistake.
regards Andrew T.
Old 4th October 2016, 02:22 PM   #19
Ok, re-wired the bridge to use 4 diodes, now I get the following voltages
V+ to V- 46 volts
V+ to ground(black wire from transfomer) 23 volts
V- to ground(black wire from transfomer) -23 volts
Which I think is expected without the smoothing capacitors in place.
geoff.
Old 10th October 2016, 03:29 PM   #20
Default Finished!
Amps are now all built and working
Many thanks to AndrewT, Mark Whitney and JMFahey for all of your help and guidance, much appreciated
FWIW, the rail voltages ended up at +/- 34VDC at the amp board.
geoff.
LM3875 Kit, too much voltageHide this!Advertise here!
LM3875 kit troubleshooting imperion Audio Sector 2 16th April 2012 05:00 AM
LM3875 KIT from ebay vinodt1347 Audio Sector 8 1st December 2010 08:28 AM
Wanted Lm3875 Kit BigBill6778 Swap Meet 5 4th February 2009 03:01 AM
lm3875 kit + other bits jimbo1968 Vendor's Bazaar 0 9th December 2006 03:29 PM
FS: BrianGT gainclone kit. LM3875 Dual Mono Kit mattjk Swap Meet 3 16th November 2004 12:24 AM
