Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 4th February 2015, 04:30 PM   #21
mozarti is offline mozarti
Peter,
As to option 3, do you connect the cap from the 680ohm resistor to the outgoing ground, chassis ground, signal ground, p+ ground, or P-ground? And am I correct that the positive side of the cap should be connected to the resistor?
Old 5th February 2015, 03:43 PM   #22
r100 is offline r100
Default change caps
Originally Posted by Peter Daniel View Post
It's most likely Yulong changing it's output offset.
As to advantage of pint 2 is that you can use much smaller cap, so better quality and you actually protect the amp against any possible offsets from sources.
Point 3 only prevents amplifying of the offsets. The amp has approx 32x gain (or 30dB) so if the the source offset is 5mV you will see 150mV at the amp's output.
The possible advantage of point 3 is that the cap, although much bigger, is not in direct signal path so it's effect may not be that obvious. Although, OTOH, there's no such thing as component not in a signal path, everything actually matters.
Is the quality of the capacitors important ? I ask because I have two 2.2uF caps on a 2 dollar amp which doesn't work. Can I use those ? (See pic.)
thank's
rupert
PS I have moved some DAC's around my setup and the funny thing is that when the USB cable is hooked up to the computer, DC offset drops to the LM3875 values as with shorted inputs. Go figure ???
Old 5th February 2015, 03:58 PM   #23
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
dc offset of 180mv. Send a message via AIM to Peter Daniel
you can use any caps, some may work better then other or you may not notice a difference at all; it all depends on the rest of equipment and listener perception
To order kits contact me through forum mail.
Old 5th February 2015, 04:02 PM   #24
Originally Posted by mozarti View Post
Peter,
Fig 1 in datasheet: http://www.google.ca/url?sa=t&rct=j&...85464276,d.aWw doesn't specify any particular orientation for that cap so you can place it either way.
dc offset of 180mv.Hide this!Advertise here!
Dc offset Vrystaat Solid State 9 14th May 2013 06:16 PM
DH-220 Clone (SMART TA-242) can't adjust DC offset using offset bias pot? beady Solid State 6 17th March 2011 10:53 AM
DC Offset JannaCassandra Chip Amps 3 26th July 2008 03:20 PM
Zero DC Offset nitin Solid State 3 6th January 2005 05:28 PM
DC offset need help again :-( djdamix Solid State 13 26th October 2004 08:38 AM
