Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 13th March 2014, 10:19 AM   #11
SimonKit is offline SimonKit  Netherlands
Originally Posted by Peter Daniel View Post
Those are MUR860
I was refering to the condensers. Are you using the 10u Panasonic FC or something else ?
Old 19th March 2014, 10:04 PM   #12
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Adding bigger caps to classic LM3875 Send a message via AIM to Peter Daniel
I normally don't use any caps there, but if anything, 10uF FC would be a good choice.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 26th April 2014, 06:33 PM   #13
jgwtriode is offline jgwtriode  United States
jgwtriode's Avatar
Yes, this is still my opinion. However, I would be using BG N 100uF caps only at the chip if the amp was intended for mid or high section of multi amp setup. For full range BG STD 1000/50 at the rectifier are still needed.
If I'm not using BG caps, Panasonic FC 1500/50 are my first choice.
Is there any advantage using 1500uf/50 vs 1000/100uf on the cap setup?
I am running Mundorf Mylitic AG+ 4 poles for the 1000uf caps on the PSU board and 100uf Panasonic Pureism XPL 100uf on the chip board?
jgwtriode
Old 3rd May 2014, 02:20 AM   #14
The rating of those large caps is not critical, more important is the type of the cap.
Your setup would be fine.
www.audiosector.com
Old 3rd May 2014, 02:37 AM   #15
CFT is offline CFT  United States
Should I replace my 1,000uFs FC to 1,500 uFs FC, would I get improvement for my mid/woofer amp (no xover)?
Old 3rd May 2014, 12:21 PM   #16
It wouldn't make much difference. If anything, use 2200uF
www.audiosector.com
Old 31st May 2014, 10:52 PM   #17
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Originally Posted by pbertino View Post
Just an update that others may find helpful.
The 10,000uf Nichicons didn't seem to affect the bass, but some detail was definitely sucked out of the music. Maybe they weren't the ideal caps.
I removed them, then replaced the basic resistors with the ones from the premium kit (caddocks and riken).
Pronounced improvement in the clarity.
If you're looking at Audiosector LM3875 kits, don't skimp. Go for the premium kit.
I also added a small subwoofer to my bookshelf speaker setup and it works great to fill in those lower frequencies.
If you want more bass and to keep the freshness, do not replace the caps. Keep the 1500uF on the main board, and put the 10000uF on the rectifier board. One for each rail. 4 for two channels
Like this
Too many projects... so little time...
Old 31st May 2014, 11:06 PM   #18
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
i like big caps too...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 9th October 2014, 11:19 PM   #19
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
Solder the feedback resistor (rf) directly to the pins with the shortest possible lead length. Even go as far as to make it a Nude Vishay.
OOOOR call me nuts, but I think it'll help you achieve a less compromised sound.
Adding bigger caps to classic LM3875Hide this!Advertise here!
Bigger caps on Ayre V5xe ? LaSeR1 Solid State 3 21st November 2013 12:00 AM
Audio Sector LM3875 Classic Dual Mono with Pass B1 jdsalinger Swap Meet 9 4th July 2013 08:59 PM
AudioSector LM3875 dual mono classic kit. gychang Swap Meet 2 2nd August 2008 01:28 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
adding caps and snubber network to LM3875 power board quickshift Power Supplies 0 19th August 2005 02:12 PM
