Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 4th November 2012, 10:21 PM   #11
Einric is offline Einric  United States
Einric's Avatar
The datasheet says that the gain setting should be no lower than 10V/V (10 volts per volt?) how does that language translate into db's?
10V/V tells me it is 10 to 1 ratio which is 20db gain correct?
With this logic I would think that 1kΩ & 86.6Ω would give me a gain of 22db.
Old 4th November 2012, 11:00 PM   #12
R.I.P.
A CD player typically puts out 2Vac to 2.3Vac.
A 60W into 8ohms Power Amplifier (maximum output ~ 22Vac) with a gain of 20times (+26dB) will clip full output signals, massively.
A 20times power amplifier does not need a gain stage in the preamp.
It needs a buffer after the volume pot, not a gain stage.
A buffer and a 2.2Vac signal will take a 10times (+20dB) gain Power Amplifier right up to the 22Vac clipping level of a 60W into 8ohms Amplifier.
If you have a +19.5dB, or +19.9dB gain stage, then you have bought/built the wrong equipment for your system.
regards Andrew T.
Old 5th November 2012, 12:01 AM   #13
Einric's Avatar
I realized that I have too much gain quite a while ago.
This preamp works great with portable media players that have low output voltage.
This is starting to make me think that I really need a Pass F4.
Old 5th November 2012, 09:20 AM   #14
R.I.P.
Then use the gain stage only for those low level inputs that need the extra gain.
Use alternative inputs to the vol pot that have no added gain stage.
All you need after the vol pot is a buffer.
regards Andrew T.
LM4780 Gain SettingHide this!Advertise here!
Anyone Care to Explain the Gain-setting Resistors on the Lm4780 Datasheet, Bridged ZLyzen Chip Amps 10 27th July 2012 07:05 PM
Need help setting the gain carshateme Subwoofers 6 28th October 2011 04:12 AM
Help with GainClone gain setting johan851 Chip Amps 35 15th February 2008 05:33 PM
Setting GAIN on GAINclones Lucas_G Chip Amps 11 20th December 2006 07:33 PM
Gain Setting HU/Amp vadi Car Audio 2 19th July 2006 11:57 AM
