Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 14th July 2012, 09:27 PM   #1
xecluded's Avatar
Default Help
I just received the standard 3875 kit and see that there are 4 1500uf caps and was wondering what are these for. In the schematics for the board, it does not show any capacitors but in the board there are 2 spots to mount capacitors, do i install 2 1500uf caps in there. I am lost. Thanks.
Old 15th July 2012, 01:25 PM   #2
xecluded's Avatar
According to the 3875 data sheet, there is a cs cap on pin1 and pin 4. Is this how the schematics should be.
Old 18th July 2012, 02:15 PM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Everything is explained here: Commercial Gainclone kit- building instructions
The schematic shows signal path only, the big caps are part of the power supply filtering and should be mounted on amp board as well.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
