Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 23rd December 2012, 03:22 AM   #31
gootee is offline gootee  United States
If your signal input and signal input ground wires are not shielded, then they too should be tightly twisted, ALL the way from the input jack to wherever they connect internally.
Actually, all conductor pairs should be twisted, or in some way kept as close together as possible. Otherwise, if they have any open area between them, they are an antenna!
(Faraday's Law is, roughly, that a time-varying magnetic field will induce a corresponding time-varying current in any conductive loop, and, a time-varying current in a conductive loop will induce a corresponding time-varying magnetic field. So, they can both receive and transmit.)
Your AC wiring (primaries, secondaries/rectifiers) is usually the worst "transmitter". And the input signal and ground pair is the worst "receiver". (They will also receive things other than just your internal AC, such as RF.) But all other pairs will also receive and/or transmit, if there is any area between their two conductors. So twist all wire pairs, if possible, including speaker pairs, and DC power and ground pairs.
If you want to shield the input pairs, instead of twisting them (since shielding is even better than twisting), a good type of cable to use is "shielded twisted pair". Using that, the signal and the ground wires are both inside of the shield. The shield is then NOT connected to the input jack's ground (signal ground). The shield should be connected to the chassis or chassis ground, and only at one end (probably the input end is better), with the other end of the shield connected to nothing.
Old 23rd December 2012, 09:29 AM   #32
Marra is offline Marra  United Kingdom
LM3875 (AudioSector) Build
Don't forget a current limiting resistor for the led in the switch.
LED calculator for single LEDs
Old 23rd December 2012, 10:03 AM   #33
MagnumOpus is offline MagnumOpus  Norway
They are supposed to be non LED, thats why I ordered them...
All my signal wires are twisted, and the boards are in the front end of the chassis, but the transformer is so big it makes a tight layout. inout and output wires are very close, but the transformer is shielded, or atleast supposed to be. I ordered custom from Toroidy.
The hum is barely audible, and the hiss, I blame my passive alps for that, I will wait to see if it gets more quiet at loud volumes when I finish my B1, waiting for the final parts to arrive any moment.
Thank you guys, you have been most awesome!
I don't know if I am to try and install the power switch, I really don't understand wiring when written and explained, I have to see pictures
Happy holy days
"Simplicity is the key to brilliance"
Old 23rd December 2012, 10:08 AM   #34
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
The power switch shows a diagram of the actual switch... I'll make you a picture later maybe.
PLEASE photo your amplifier and let us see it.
By the way mine has RF in it despite capacitors are certain pins. I can't figure out why at all. It doesn't come from my RCA's because volume doesn't change it. The good part is it never bothers my listening experience. It is silly though that it happens. Wish I knew why. (have tried to figure it out for years, Peter tried to help, no avail with any changes in grounding etc) Just saying, love the thing anyway.
Old 23rd December 2012, 10:56 AM   #35
I just went by the diagram which appeared with your link.Just use your dmm to check the connections on the switch;does it have 4 or 6 connections?
Old 16th January 2013, 01:45 PM   #36
Interesting. What are the symptoms/effects or measurements that indicate it is RF?
Do you have RF filtering on the inputs? Do you have RF filtering on the outputs? (Everything is an input, for RF.). Do you have RF filtering on the DC supply line inputs to all chips? Can you describe what you have tried, so far?
If you use RCA input cables with shields, the shields might be picking up RF. There are two-wire RF filter topologies that should work for that. Look in chapter 6 or 7 of Walt Jung's book "Op Amp Applications", which is a free download at analog.com . Also discussed there are other methods for defeating RF, and for filtering power amp outputs and dc power. Twisting speaker wires comes to mind, as does installing a 5 uH or so high-current RF CHOKE in each of the speaker lines, like the bourns/j.w. miller toroidal types that can be seen at mouser.com, which are very reasonably priced. I guess those might also work in other places. Never tried them anywhere else. But my Magnepan planar speakers seem to make wonderful antennas.
Old 16th January 2013, 05:58 PM   #37
Been through it all, I don't even care anymore.
Plus my stereo would sound worse with chokes in it.
Old 16th January 2013, 06:18 PM   #38
Understood. It's your system.
But with only FIVE MICROHENRIES, and very thick wire good for 20 amps, there would be NO direct audible effect.
Old 16th January 2013, 07:55 PM   #39
Thank you all for the reply.
The hissing is my passive pre's fault, its more noisy with the volume just above half, more quiet when all the way full, and less so at lower leves. I don't care about that since it will go away with my new B1.
The RF noise, is only somewhat audible when the room is silent, nothing heard when I play music.
The on/off switch will go in later when I buy a drillbit big enough.
It has five connections, three in the middle and to flanging them.
I have heard some pretty expensive (by my accounts) amps from Marantz and Denon, Rotel and Luxman in the pricerange of about $500 to $3000 and this just kicks their butts...so good...
Thank you Petter Daniels for making this possible.
LM3875 (AudioSector) BuildHide this!Advertise here!
Audiosector LM3875 - Volume Control / Preamp options batdan Audio Sector 10 5th June 2011 01:36 PM
LM3875/AudioSector owners, need measurements MagnumOpus Chip Amps 0 29th March 2011 06:18 PM
audiosector lm3875 transformer ? mr scratch Chip Amps 2 9th March 2011 06:55 PM
AudioSector LM3875 dual mono classic kit. gychang Swap Meet 2 2nd August 2008 01:28 PM
Audiosector premium LM3875 gainclone sts9fan Swap Meet 5 16th November 2007 01:10 PM
