Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 13th November 2014, 04:48 AM   #311
hartbigsky is offline hartbigsky  United States
So I have been teaching myself the different components of this regulator by reading textbooks on my own. I understand the voltage divider on pin 2 of the AD811. Pin 3 I am still not so sure of. Is it in this configuration to be used in a reverse biased mode, in that at 2.5V it functions as an open circuit with limited current not as a 2.5V reference source? What will pin 2 be seeing on pin 3. I know the 811 is a current sensing op amp. With pin 6 output driving the vertical DMOS what is happening at +in, I know under most circumstances no real current flows into an op amp[op amp rules] but rules can be broken under certain circumstances. I guess I am struggling with how this regulating circuit is functioning on my own. Anybody have a non textbook length explanation unless you like to type? Thanks for any help!
apprentice DIYer,
Steve
Old 13th November 2014, 06:37 AM   #312
Sorry in above post I meant to say unlimited current flow as opposed to reverse bias breakdown current flow. In all the examples I find the anode is at ground and the resistor at the + rail and the reference voltage at its junction. I don't now what you get when the resistor is at ground and the cathode at + rail, what is +in on the AD811 getting, just ground making -in[pin2] virtual ground? What is the diode (voltage regulator) doing? Is it a 2.5V drop as a zener function? Hope someone can help
Steve
Old 13th November 2014, 06:55 PM   #313
[IMG]http://www.diyaudio.com/forums/diy question.jpg[/IMG]
If this file opens see if I am on the right track from the 2 previous post. Thanks!!
Steve
Old 29th January 2015, 02:33 PM   #314
Mickey Solder is offline Mickey Solder  Germany
To see the fine pics, I really passed the registration procedure. This is an inspiring article, even to beginners like me. Can you image a guy, looking forward for to his first DAC design based on the TDA1543?! For sure, it's hard to remember for you folks.
Old 12th April 2015, 08:08 AM   #315
johnm is offline johnm  United Kingdom
johnm's Avatar
Are Peter Daniel PCBs still available for this DAC? I made one 6 years back and enjoyed the process, then stupidly sold it a few years later. I'd like to build another.
John.
Old 14th June 2015, 02:05 PM   #316
johnm's Avatar
I'll assume not then. Pity...
Old 17th September 2016, 11:04 AM   #317
Piotr is offline Piotr  Poland
Piotr's Avatar
Hi, have you been discussing the subject of i2s input series resisors causing HF filtration? Is this a good idea or not so good?
Old 1st December 2016, 04:36 AM   #318
naim2 is offline naim2
Did anyone compared Peter's DAC v1 vs v3? Just wondering how they sound different and how the v3 improved on the v1. any comment appreciated. thanks David
Old 16th February 2018, 08:29 PM   #319
Bartb is offline Bartb  Slovenia
Pushing the limits of TDA1543 NOS DAC
Originally Posted by Alexandre View Post
Yes, try it, I have a correction to what I wrote earlier though. A single inverter might be needed as well. But the Tent clock output goes directly to the BCK of tda1543, which is the jitter critical input.
I will draw a schematic later.
Best,
Alex
Hello !
you say (it's quite some time now ) the BCK is the jitter critical input...
I cannot understrand this. Is it not the WS which is jitter critical?
The moment the DAC converts and outputs the analog signal at 44.1 Khz ? (the WS) Thanks B.
Old 17th February 2018, 12:09 AM   #320
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
If you refer to the datasheet (fig5, format of input signals) you'll see that everything is 'seen' by the chip only when there's a clock edge. So only when a clock rising edge follows the WS falling edge is the current sample converted. In fact there's a delay of a clock cycle after that edge before all the serial data has been received so its impossible for the DAC to convert a sample on the WS transition.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Pushing the limits of TDA1543 NOS DACHide this!Advertise here!
FS: NOS TDA1543 DAC 2A3SET Swap Meet 0 24th March 2011 07:10 PM
Pushing Aleph P to limits - Passive Tri-amp Alves Pass Labs 4 12th September 2006 01:56 AM
TDA1543 and CS8412 NOS DAC Igla Digital Source 3 7th March 2006 07:27 PM
Nos Tda1543 Dac. IpsilonSound Digital Source 0 4th June 2004 06:25 PM
TDA1543 nos dac question... setmenu Digital Source 13 2nd June 2004 12:03 PM
