Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 7th April 2014, 09:10 AM   #291
uncle_leon is offline uncle_leon  Poland
uncle_leon's Avatar
Any similar XOR Gate should do. Although my suggestion would be to omit this chip altogether, unless you expect to be swapping polarity very often. You can correct absolute phase by simply swapping your speaker cables so that amp "-" goes to speaker "+". Just remember to swap cables for both speakers, otherwise you will end up with speakers playing out of phase.
Studio Zy - natural, hand-crafted components for hi-end audio.
"Dare to be different, and you may stumble upon something amazing."
Old 8th April 2014, 09:28 PM   #292
PreSapian is offline PreSapian
?? the chip is used for splitting the data signal for the two chips.
Old 22nd April 2014, 04:12 PM   #293
hartbigsky is offline hartbigsky  United States
Hi Peter,
I am looking at images from your audiosector website that shows a version of your TDA1543 SPDIF DAC on a single PCB. It has a single Hammond 16V(229D16) transformer. I am a fledgling builder in the digital realm and was hoping to build this project as a learning tool. Am I right in the one transformer? If so did this operate both DAC and receiver with 16V instead of the 18V shown in this DIYAudio build? If I can do with single is there any forum conversations on that design I can reference?
Thank you for your help, your ideas and build skills are inspiring.
Steve(hartbigsky)
Old 22nd April 2014, 06:34 PM   #294
burninggecko is offline burninggecko  United States
burninggecko's Avatar
I built the analogue section of the design posted in Uncle_Leon's post #237. Currently it is fed with a I2S signal from my Amanero, but next step will be to build the digital section with the cs8412.
For IV coupling capacitors, I am using some Dayton Audio 4.7uF 250V Polypropylene Capacitors from Parts Express. I wanted to try some other capacitors but wasn't sure if I needed to stick to the 4.7uf value. Are there any good alternatives that can be recommended (in lieu of Blackgates)? Should I stick to 4.7uf? TIA for any advice.
Link to post # 237:
Pushing the limits of TDA1543 NOS DAC
Old 22nd April 2014, 07:11 PM   #295
Please disregard my post, I just saw post #247 which answered my question
Old 23rd April 2014, 09:09 PM   #296
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Pushing the limits of TDA1543 NOS DAC Send a message via AIM to Peter Daniel
Originally Posted by hartbigsky View Post
Hi Peter,
Steve(hartbigsky)
You can find forum discussion here: Audiosector USB DAC
It's perfectly fine to use single transformer. I'm using Hammond with dual 8V windings: one for DAC, one for receiver circuit.
To order kits contact me through forum mail.
Old 25th April 2014, 08:24 PM   #297
Hierfi is offline Hierfi  Canada
[QUOTE=Peter Daniel;3902632]You can find forum discussion here: Audiosector USB DAC
Your implementations always look very good Peter. As an aside, what are the power supply inductors and those nice PCB mount RCA jacks shown in your link? Gerrit
Old 27th April 2014, 03:14 AM   #298
Thanks for answering my post, how do you get your p2p so close???!!!!Are most contacts the part leads? Also one image looks like the TDA1543 are sitting on a silver case of some type? Do you have any p2p instructions anywhere? Thanks!!!
hartbigsky
Old 3rd May 2014, 12:44 PM   #299
TDA1543 sits in a socket, for easy swapping when offset needs adjustment.
I try to use the component leads for most of the connections; with some practice, making it p2p like that is not a big deal. Besides the pictures and schematics, there's no other instructions.
Old 7th May 2014, 02:31 AM   #300
Is the socket metal? It looks shiny, or is there just shielding you place around socket. The 8 pin dip sockets I have are plastic body, or do you use something different? Once again thanks for your time!
Pushing the limits of TDA1543 NOS DACHide this!Advertise here!
FS: NOS TDA1543 DAC 2A3SET Swap Meet 0 24th March 2011 07:10 PM
Pushing Aleph P to limits - Passive Tri-amp Alves Pass Labs 4 12th September 2006 01:56 AM
TDA1543 and CS8412 NOS DAC Igla Digital Source 3 7th March 2006 07:27 PM
Nos Tda1543 Dac. IpsilonSound Digital Source 0 4th June 2004 06:25 PM
TDA1543 nos dac question... setmenu Digital Source 13 2nd June 2004 12:03 PM
