#241 |
Call me a putz... I want a USB PCB board that I can solder parts onto.
#242 |
Those two AN8005 are bare minimum, I was rather talking about replacing them with discreet regulators, which is not always needed.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#243 |
Hi
It’s possible to replace a CS8412 chip with CS8420 chips ??? I can't find more CS8412/14 chip. Thanks Ivo-Cici Last edited by Ivo-Cici; 26th December 2012 at 09:22 PM. |
#244 |
No, you can't. CS8420 is sample rate converter, not a S/PDIF reciever, like CS8412/14.
#245 |
CS8412 is plentifully available on ebay. Look for the CS8412CP if you are after the DIP version.
Ebay search for CS8412.
Studio Zèy - natural, hand-crafted components for hi-end audio. "Dare to be different, and you may stumble upon something amazing." |
#246 |
Thanks Guys
#247 |
One more thing has just occurred to me, that I forgot to mention, regarding the simplified schematic above. It will be obvious to most, but I will say it, just in case - the output capacitors (C13 and C14) need to be non-polarised, so either film caps or non-polar/bi-polar electrolytics. The value is not very critical - you could use 10x bigger or smaller without running into any serious trouble.
#248 |
A point of clarification that seems likely to have already been addressed. I have one of those passive output NOS 4x1543 DAC's. As the TDA1543 literature calls for an inverting opamp connected to the output is it reasonable to conclude that these passive output DAC's require an inverter on the data line to produce the correct phase?
#249 |
I think you are correct on the assumption that the phase is reversed when using passive I/V conversion. But does it matters to you ? You could try to phase reverse your speakers and listen if there is any difference on the same music track.
Cheers Flemming |
#250 | |
| Thread Tools | Search this Thread |
| FS: NOS TDA1543 DAC | 2A3SET | Swap Meet | 0 | 24th March 2011 07:10 PM |
| Pushing Aleph P to limits - Passive Tri-amp | Alves | Pass Labs | 4 | 12th September 2006 01:56 AM |
| TDA1543 and CS8412 NOS DAC | Igla | Digital Source | 3 | 7th March 2006 07:27 PM |
| Nos Tda1543 Dac. | IpsilonSound | Digital Source | 0 | 4th June 2004 06:25 PM |
| TDA1543 nos dac question... | setmenu | Digital Source | 13 | 2nd June 2004 12:03 PM |
