#211 |
How much is the USB DAC Kit now? Can the open chassis be bought also?
My Blog: http://www.diyaudio.com/forums/blogs/magnumopus/ |
#212 |
He stopped selling them. Shame, I'd like an updated one....
#213 |
It is still possible to DIY one - the schematics are available, and the updated version is actually simpler than original. I can help with alternate parts choices (what to use instead of Black Gates etc.).
Studio Zèy - natural, hand-crafted components for hi-end audio. "Dare to be different, and you may stumble upon something amazing." |
#214 |
Uncle leon. I hav eone 90% completed. What would you suggest for cap replacements?
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#215 |
Which exact power supply arrangement you are using? I am assuming you do not have access to any Black Gates at all?
#216 | |
Should have bought one when I had the chance...
#217 | |
They were always better than the rest of my equipment. They are insanely musical with power conditioning (good, not transformers). Peter was also kind enough to solder on the pesky SMD chip with his kits. Last edited by Destroyer OS.; 20th November 2012 at 04:52 PM. |
#218 | |
#219 |
Interesting. The build still looks intimidating because of the mounting distances etc. I sort of enjoy plug-n-play solder project kits though
#220 |
Onw in the updated, balanced version. Nope. I have NIchicon KG mounted currently. Bypass caps are Vishay MKP 1837. Output caps are Auricap. Everything else as spec'd
| Thread Tools | Search this Thread |
| FS: NOS TDA1543 DAC | 2A3SET | Swap Meet | 0 | 24th March 2011 07:10 PM |
| Pushing Aleph P to limits - Passive Tri-amp | Alves | Pass Labs | 4 | 12th September 2006 01:56 AM |
| TDA1543 and CS8412 NOS DAC | Igla | Digital Source | 3 | 7th March 2006 07:27 PM |
| Nos Tda1543 Dac. | IpsilonSound | Digital Source | 0 | 4th June 2004 06:25 PM |
| TDA1543 nos dac question... | setmenu | Digital Source | 13 | 2nd June 2004 12:03 PM |
