Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 5th March 2012, 04:14 PM   #181
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
The HC86 can be thought of as a conditional inverter - with data going into one input, if the other input is 0 then it won't invert, with this second input at 1, it will. Incidentally since the TDA1543 was originally designed to be used with inverting (opamp) I/V, it contains inversion as a matter of course. So to get true phase out of it in passive I/V (as in the Muse) you'd need to run with one input of the HC86 = 1 so that it inverts the digital data. I mentioned this point on the Head-fi (800+ posts long) thread on the Muse
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 13th March 2012, 06:25 AM   #182
idjoel2000 is offline idjoel2000  Indonesia
hi, sorry for resurrecting an old thread
i have hifiman hm601 portable player which occupies tda1543 in it. from what i can tell, it uses 5v voltage regulator to feed stable supply to the dac chip. the I/V stage is a low pass filter occupied by LM833 and JRC4560
what is the suitable bias resistor value in pin 7? is there any calculation for it? i can't find any useful reference regarding this Rref in the tda1543 datasheet. i want to achieve maximum sound quality and i don't care about the battery life (i can play with the I/V stage & headphone amplifier stage later to achieve longer battery life)
thanks in advance
Old 13th March 2012, 09:13 AM   #183
triode_al is offline triode_al  Netherlands
triode_al's Avatar
thanks in advance
The standard Vref feeds the voltage reference for the opamp.
To get high quality go passive, then you must load the Vref pin with a resistor and also load the output with a resistor. The values depend on the voltage you have (and the number of parallel units).
It can be done with 5 volt but you get higher quality with about 7 Volt (i have that) without warming the device.
I made a table once of most used values but must look it up.
Anyway, you must have a potmeter for Vref, and a variable Vb too (best is between 6-7.5V) so you can set the operating points. There is a point of equilibrium where the saturation of the top and bottom of a 0 dB sine wave are equally low. (You can see it on a scope).
SPU --> tube MM/RIAA;
Pass buffer -->300B SE Anzaï Zaïka; --> FE103 sigma TQWT
Old 13th March 2012, 02:12 PM   #184
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Pushing the limits of TDA1543 NOS DAC Send a message via AIM to Peter Daniel
You can find the info how to calculate Rref here: http://www.diyaudio.com/forums/digit...tml#post173483
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 13th March 2012, 04:23 PM   #185
peter, sorry to bother again. but i need to ask something
it seems like I/V stage, supply voltage, and Vref are playing key role for calculating the Rref value
but as i mentioned earlier, HM601 uses active I/V stage (2 opamps constructing a low pass filter), and there is no I/V resistor between the dac output and opamp input.
can i calculate the Rref by simply remove the existing Rref and measure the current flowing from the Vref to ground, then simply divide 2.2V with the measured current to obtain the value of Rref?
and why did you suggest using 3R8 ohm for Rref in this post?
Originally Posted by Peter Daniel View Post
Using Mills is perfectly fine as you are changing other aspects of design anyway.
Please note that for a single DAC chip, the current setting resistor should be 3R8
sorry for the noob questions..
Old 14th March 2012, 02:18 PM   #186
3R8 is for voltage regulator, not V ref.
As to other question, I'm afraid I can't be much of help.
www.audiosector.com
Old 14th March 2012, 02:49 PM   #187
abraxalito's Avatar
It depends what quiescent output voltage you want from your LM833s. There's a minimum value it can be - 910R (in E24 series), but no maximum.
To come up with an optimum we'd need to know the supply rails to the I/V stage (LM833) and its feedback resistor value. That would allow setting the quiescent output voltage mid-way between the rails.
Old 15th March 2012, 03:47 AM   #188
i'll look into that later, but as far as i know, the rail to rail supply of LM833 is -5 to +5V. so we need to set the Vref at 2.5V?
Old 15th March 2012, 04:28 AM   #189
abraxalito's Avatar
If by Vref you mean pin7 of the TDA1543, its set internally to 2.2V. Hanging a resistor off that pin, provided its not smaller than 910R won't change the voltage.
Given that the LM833 has balanced supplies we'd want its output to sit at 0V when no music is playing. Are the positive input pins (pin3,5) connected to pin7 of the DAC chip? If they are (even via some series resistance) then the LM's outputs would sit at 2.2V with no current coming out of the DAC.
The mid-scale current for the 1543 is 1.15mA typically, to get the bias current to equal this (for no net current out) needs 0.575mA as the Vref current, meaning Rref=3.8k. However we'd not like 2.2V out of the LM833, rather 0V which is done by increasing the bias (decreasing the Vref resistor below 3k8). The amount depends on the gain of the LM833 stage but I'd make a guess that for 2.8V peak signal the I/V resistor will be 2k4 meaning the bias needs to deliver an extra 1mA roughly to get the output to zero volts. Thus I'd go for a 2k Vref resistor as first stab
Old 15th March 2012, 05:24 AM   #190
thank you for the very clear explanation abraxalito. i have to check the pcb first with my multimeter to test the connection
to manually set the LM833 output at 0V, can i just play with Rref until i get 0V at the LM833 output? we can measure LM833 output by tapping the red and black probe to pin1 of the LM833 and active filter ground right?
will report back here again after i got something to report. thanks!
Pushing the limits of TDA1543 NOS DACHide this!Advertise here!
FS: NOS TDA1543 DAC 2A3SET Swap Meet 0 24th March 2011 07:10 PM
Pushing Aleph P to limits - Passive Tri-amp Alves Pass Labs 4 12th September 2006 01:56 AM
TDA1543 and CS8412 NOS DAC Igla Digital Source 3 7th March 2006 07:27 PM
Nos Tda1543 Dac. IpsilonSound Digital Source 0 4th June 2004 06:25 PM
TDA1543 nos dac question... setmenu Digital Source 13 2nd June 2004 12:03 PM
