#151 |
My intentnion was to listen to SE version and if I like what I hear, move to the balanced version. In rereading the thread, I see that Bobken seems to suggest that he used different components on his SE version. I am assuming that the choices I am making accroding to your posted schematic will give me a good idea of the sound. Would you agree or do you think I need the 8416 to get a true sense. IT is a lot of money and I want to be judging a good representative of the proposed product. FYI, in using I2s from 7210 in CD player, I had planned on upgrading the PSU for that chip to try to minimize detrimental effects. THanks for pointing out the resistor for SE.
#152 |
Actually you may get better results without 8412 (we are not using 8416)
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#153 |
Sorry, too many numbers floating arounf in my head. BTW, I found your thread tapping trick in anoth thread and cannot thank you enough for the time and effort you have saved me with just that one suggestion. I'll let you know how it turns out.
#154 |
Dear Peter
the switch AD811, is there a particular one? Farnell have different: ad811Arz,ad811anz etc happy newyear |
#155 |
Bobken,
In rereading the thread, you seem to suggest that you used different resistor types for your SE version. Cold you post those if this is true. |
#156 |
Bobken prefers nude Vishays, TX2575, in all locations.
As to AD811, I choose DIP version
#157 |
Just playing around, i used rn55 resistors to try this out with my CD player. I only changed the IV stage. You can tell it has potential. The music has a certain ease to it. I would call this analogue. I am looking forward to using actual components. I had the good fortune of getting nude Vishays for half price for the psu. I will stick with the Caddocks on the IV.
#158 |
Hello Bob,
Long time no hear. Nice to see you are getting such good results with my old shunt regulator design though I have moved it on considerably in performance over the last few years. It now has a much wider operating bandwidth, faster transient response and settling time, lower noise and lower output impedance over a much wider bandwidth. Regards Paul
Paul Hynes |
#159 |
bobken and Paul,
Can the shunt regulator be used at 3.3V.....and, if so, what values need changing? Can the 811 operate that low? Thanks |
#160 |
Ric,
The AD811 will not operate with a 3v3 rail. This particular topology is also rather noisy if you were considering using it in your OPPO Sabre dac supply upgrades. The Sabre DACS are very sensitive to noise on the supplies. I only produced this 811 design commercially for a couple of years, as it was too noisy for sensitive power lines and I needed a product that could work down to 3v3. I developed the design topology further to reduce noise, extend the operating bandwidth out to 1 GHz and allow 3v3 operation.
Paul Hynes |
| Thread Tools | Search this Thread |
| FS: NOS TDA1543 DAC | 2A3SET | Swap Meet | 0 | 24th March 2011 07:10 PM |
| Pushing Aleph P to limits - Passive Tri-amp | Alves | Pass Labs | 4 | 12th September 2006 01:56 AM |
| TDA1543 and CS8412 NOS DAC | Igla | Digital Source | 3 | 7th March 2006 07:27 PM |
| Nos Tda1543 Dac. | IpsilonSound | Digital Source | 0 | 4th June 2004 06:25 PM |
| TDA1543 nos dac question... | setmenu | Digital Source | 13 | 2nd June 2004 12:03 PM |
