Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 12th December 2010, 11:41 AM   #1
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Wink My completly-HUM Free LM4780 setup
I would just contribute, with (after long time stroggling) - Well at least in my setup... a completly HUM Free setup / connections !
After trying a lot of setup's including PWR-stargnd / linein-stargnd... and all those trick's, i finally found that the HUM, was comming from my twistedpair RCA inputs.
Well, i tried using shielded cable, and Humming suddently stopped, now it was only very low. When disconnecting one- end of the shield at the RCA side, all humming is gone now I think it might be due to a little gnd-loop ind the shield of the cable.
Well take a look at my picture.
DCG3 Dual DCSTB, R2R DAC in build (2 ReflectorD's (+5VDC/+3.3VDC) + SSLV1.1 (+/-12VDC))
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
My completly-HUM Free LM4780 setupHide this!Advertise here!
2x LM4780 + DRV134 = hum Need grounding help! maxw Chip Amps 55 1st August 2006 02:17 PM
LM4780 which setup should i use? filholder Chip Amps 6 21st March 2006 12:58 PM
LM4780 Hum. ethermion Chip Amps 0 3rd February 2006 11:20 PM
