Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 25th November 2010, 02:35 PM   #1
Default Audio Sector DAC - one side stopped working
I have been using Peter's great D/A converter and enjoying it very much.
Suddenly, while I was listening to music, one side started to make a noise (like white noise),
came back to normal sound and then died.
So now only one side is working.
Please help,
what do you recommend to check or replace?
Thanks,
Lorent
Old 26th November 2010, 05:07 PM   #2
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Check the voltages as per attached schematic first.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 28th November 2010, 06:34 AM   #3
Everything is fine.. I have found a small piece of metal on one of the ICs.....
Removing it cured the problem...
Cambridge Audio A3i stopped working... Franne500 Solid State 1 1st May 2008 02:46 PM
FS: Audio Sector DAC $180 sts9fan Swap Meet 2 8th June 2007 01:46 AM
Finished Audio Sector NOS DAC* vdi_nenna Digital Source 4 4th February 2007 05:49 PM
Help with Audio Sector NOS DAC vdi_nenna Digital Source 14 14th January 2007 03:31 AM
Page generated in 0.07288 seconds (69.08% PHP - 30.92% MySQL) with 11 queries
