| Audio Sector Kits & PC boards from AudioSector |
#11 |
Thanks for the tips. I'll try it as is first and then if bass performance needs improving, I'll add some 4700uF-10,000uF caps on each c1/c2.
Even with that extra capacitance added, the snubber components are still optional as well, yes? |
#12 |
Yes, snubbers are optional. Generally they supposed to improve definition of bass when large caps are being used. In a long run I found them too manipulative to a sound.
Some additional comments here: my first try at a LM3886 layout, any comments/suggestions? Blackgate caps out of production, so...
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#13 | |
The quality of these boards is quite good. And they look great too ![]() Since I will be using both the stereo 4 channel amp and the 2 channel parallel amp with 4ohm speakers, I was planning on going a little different route with the cooling. Instead of using the supplied insulator film between chip and heatsink, I'm going to isolate the heatsinks from the chassis and attach the chips direct to the heatsink (with compound of course). I'm thinking this should provide at least slightly more effective cooling. My plan is to use (2) rackmount cases, 3U size and put 2 pieces of aluminum heatsink in each one run parallel with each other. Each piece will cool one chip. Heatsink size for each chip is 10" x 3.5" x 2". Fins are 1.9" tall and .08" thick with a base thats 0.4" thick. I'm also considering picking up a small piece of copper bar between the chip and aluminum...might be overkill though. The heatsink material can be seen here: It would be cut in half to provide the sizes needed. Heat Sink DIY HiFi Amplify Kit IGBT Cooling 10"x7"x2" - eBay (item 250577005422 end time Feb-14-10 21:05:14 PST) The rackmount case can be seen here: http://cgi.ebay.com/3U-Audio-Rackmou...item5633f61111 One transformer per case, I dont think there will be any issues with fitting everything in there
#14 |
Just DIY!
Hi Peter,
From your LM4780 kit, what has to be changed to run it in Parallel mode? Thanks Do |
#15 |
You will find all the info here: Kit arrived
#16 |
Just DIY!
Yeah! me again...!
![]() Do you also have instructions for bridge mode. Must be pretty similar to parallel mode. Thanks Do |
#17 |
Bridged mode is the same as stereo version described here: AudioSector-chip amp kits, dacs, chassis
Use green option on schematic here: http://audiosector.com/lm4780%20amp.pdf Please note that the amp won't convert unbalanced signal to balanced. You can use transformers for that purpose: Commercial Gainclone kit- building instructions
#18 |
Just DIY!
Hi Peter,
I was thinking about using a BurrBrown DRV134. What do you think about that? Using a transfo, I would need a really good quality one in order to not alter the sound. Do you have an example of what you would use as a very good quality transfo for this purpose at Mouser or Digikey or Parts Connexion... This is an example I was able to find but don't know if it is a good choice or if I can find this in Canada. Don't know how to implement it either for both XLR and SE as input... DIY BPA300 v2 6x LM3886 300W audio Amplifier Thanks Do |
| 31 Band Equalizer "the t.eq" "TQ-60" schematic wanted | tiefbassuebertr | Solid State | 2 | 29th March 2010 03:45 PM |
| Wanted to Buy: Pairs of 5-1/2";6-1/2";8";10" Seas Aluminum Woofers | dtm1962 | Swap Meet | 0 | 15th January 2010 04:38 PM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Randy Slone's "Fig 11.4" (Self's "Blameless"?): PCB layout | tcpip | Solid State | 126 | 15th February 2007 04:50 PM |
| "mass added to cone" I'm confused about it's meaning | Jimmy154 | Multi-Way | 12 | 8th July 2002 02:53 AM |
