Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 3rd February 2010, 08:46 PM   #31
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I think those are RN55
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 11th February 2010, 10:46 PM   #32
Hi Peter,
where do you get those washers, are they from mcmaster ?
Old 11th February 2010, 10:49 PM   #33
Those are commonly used in aircraft industry, I'm not familiar with any retailer that sells them. If mcmaster don't have them, I don't know who else would.
www.audiosector.com
Old 12th February 2010, 01:35 AM   #34
Hi Peter,
I have another question, what is the value of the resistor on the display board.
Old 12th February 2010, 01:58 AM   #35
I'm using 10k
www.audiosector.com
Old 2nd March 2010, 05:38 AM   #36
Netdewt is offline Netdewt  United States
What is the CD holder made of? What actions are necessary to put on and take off the CD? Is it modified from the original?
Old 2nd March 2010, 05:45 AM   #37
You mean the clamp? It's taken out of the boombox.
It works exactly same way as analog turntable: lift the (magnetic) clamp, change the disc, put the clamp back on.
www.audiosector.com
Old 2nd March 2010, 12:31 PM   #38
Setting a new book mark here... Great summary report Peter! MUCH easier than the three-day epic I went through for the first one!
Thanks!
Old 2nd March 2010, 03:09 PM   #39
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Originally Posted by Peter Daniel View Post
Now comes the PS part.
48VA Hammond transformer (166L24) fits perfectly in a Hammond 1590T enclosure. The diodes are mounted directly to connector socket and the whole thing came out quite elegant and simple.
Is it safe to leave those msr860 floating around in there? The backs of them are connected to the output pin. Did you insulate them?
Old 2nd March 2010, 03:40 PM   #40
The don't touch anything, so I don't insulate them.
www.audiosector.com
CD PRO 2 - The making of a high end CD Transport Peter Daniel Digital Source 439 12th January 2010 08:09 PM
Wanted: Leftover DAC from an upgraded CD player, or CD player with broken transport. Spasticteapot Swap Meet 0 7th October 2006 08:12 PM
CD Player vs. CD Transport using CD-PRO2 module tomchaoda Digital Source 27 22nd May 2004 08:29 AM
CD-ROM as a CD Transport ruangrit Digital Source 4 29th April 2003 01:34 PM
Page generated in 0.14025 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
