| Audio Sector Kits & PC boards from AudioSector |
#201 |
I've just gone back to original small cap in 906 and tried oscon 47/16 in 916.
Sounds pretty good so after all the experimentation my position pretty much the same as the start of this thread. So my clone will remain like this, full bodied sound with more detail than you can take in. ![]() Next step is to get it into it's case and hopefully it will continue to improve. 2kg lead shot ![]() mock up with spare transport
#202 |
I've put together all pieces and I have the player running, digital out is arount .5 v
Dac locks onto signal and plays, only I get a drop out every 15 to 20 seconds. Power supply seems ok with constant 8v. The drop out is for just a split second and continuosly repeats every 15 to seconds. Any suggestions as to what to check for, I have not removed any parts from digital boards yet. I've posted on the original thread also, but have had no answers yet. |
#203 | |
#204 |
Tony, unfortunately there is no Black Gate equivalent among the newer caps. Black Gates are still the best and only.
For information about other caps you could have a look at my "big capacitor test": Finally, an affordable CD Transport: the Shigaclone story I have tested more caps since but the results haven't changed much, except: - Some people find Os-Cons sound too hard for their taste and for those I recommend replacing them with Starget in the C916; in the PSU replace it with Rubycon ZL/Nichicon FG or another Starget. - I now consider "no cap" at C916 inferior to both OsCon and Starget. - BG STD 1000uF/50 is a bit better than BG STD 1000uF/25. - BG Nx HiQ 47uF/6.3 is better than BG N 47/50. and also: - all electrolytic caps can be improved no end by wood-modding. I hope this helps
Studio Zèy - natural, hand-crafted components for hi-end audio. "Dare to be different, and you may stumble upon something amazing." Last edited by uncle_leon; 14th March 2012 at 12:06 AM. |
| CD PRO 2 - The making of a high end CD Transport | Peter Daniel | Digital Source | 439 | 12th January 2010 08:09 PM |
| Wanted: Leftover DAC from an upgraded CD player, or CD player with broken transport. | Spasticteapot | Swap Meet | 0 | 7th October 2006 08:12 PM |
| CD Player vs. CD Transport using CD-PRO2 module | tomchaoda | Digital Source | 27 | 22nd May 2004 08:29 AM |
| CD-ROM as a CD Transport | ruangrit | Digital Source | 4 | 29th April 2003 01:34 PM |
| Page generated in 0.08401 seconds (72.43% PHP - 27.57% MySQL) with 11 queries |
