The CD Transport - Page 13 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 18th November 2010, 06:21 PM   #121
Ah, thanks.....
Old 18th November 2010, 07:16 PM   #122
iwok is offline iwok  Poland
Originally Posted by Peter Daniel View Post
It's not a problem, it's normal. Usually there is a coupling cap in a DAC (0.01uF or similar) and you don't have to do anything. If DAC does not lock to your transport, install such coupling cap at the output.
Thanks Peter. My DAC communicates with the transport without any problem. I am just thinking if this constant voltage is not dangerous to my DAC when used for a longer time..
Old 18th November 2010, 07:24 PM   #123
Kim Schultz's Avatar
I got my birdnest setup running today with the original trafo and a Vishay W02G diode bridge with a Evox-Rifa 1nF cap between each leg. Two Panasonic FC 1000uF / 25V caps and a MC7808C regulator. The C916 was replaced with a Panasonic FC 22uF / 100V cap.
The two output resistors were just some old ones taken from the drawer.
The 5 components suggested by Peter was removed.
The transport is feeding a DPA Enlightenment DX32 DAC.
Its cool when it works the first time, but I cant comment on the sound yet until I try it up against my DPA transport.
Old 19th November 2010, 12:04 AM   #124
Iwok: its not dc voltage - its the spdif signal, which is so fast that your dmm thinks that its dc.
Old 19th November 2010, 06:12 AM   #125
any reason why u need such a large deviation from the original value for C916?
Old 19th November 2010, 08:41 AM   #126
Commstech, no reason other than Peter recommend a 33uF or 47uf BG but I only had a 22uF if I wanted a Panasonic FC.
Ill see if I can find some BGs to experiment with another powersupply.
Old 19th November 2010, 11:04 AM   #127
slawney is offline slawney  Germany
Thanks Peter. You provide solid, easy-to-follow guidelines for this project.
If I may, I suggest putting a .27Ohm - .47Ohm 2-5 Watt resistor between the LM7808 V+output and the 1,000uF-470uF decoupling cap that follows it. LM78xx regulators are notorious for oscillating into low impedance loads and a low impedance cap like a large value Black Gate or Rubycon (esp. with a bypass) after a commercial regulator will result in oscillation. The added benefit of this resistor will be to provide a last low-pass RC filter for the supply before it reaches the active components. The resistor does not need to be low-inductance, in fact, inductance would add further HF filtering, which would be beneficial here.
Old 22nd November 2010, 09:03 PM   #128
billo44 is offline billo44  United Kingdom
billo44's Avatar
Default Help
That is my exact problem....
So excuse me for being 'a bit of a thicky' (there is no excuse really!) but... the (0.01uF or similar) cap goes across DOUT and GND after the output resistors? Or in line on DOUT?
DAC locks on to other sources OK. Using the built in DAC in an Onkyo Integra A-701 for now.
I can only think of electronics by using plumbing analogies, this will only get me so far I guess!
I'll probably have found out by the time anyone answers..... I'm on Japan time and at the start of the Labour Day holiday here.
regards all
Bill
Old 22nd November 2010, 09:12 PM   #129
You are up too early.....
Old 22nd November 2010, 10:12 PM   #130
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
... the (0.01uF or similar) cap goes across DOUT and GND after the output resistors? Or in line on DOUT?l
It goes in line with output, after the resistors.
www.audiosector.com
Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it. - JC
CD PRO 2 - The making of a high end CD Transport Peter Daniel Digital Source 439 12th January 2010 09:09 PM
Wanted: Leftover DAC from an upgraded CD player, or CD player with broken transport. Spasticteapot Swap Meet 0 7th October 2006 09:12 PM
CD Player vs. CD Transport using CD-PRO2 module tomchaoda Digital Source 27 22nd May 2004 09:29 AM
CD-ROM as a CD Transport ruangrit Digital Source 4 29th April 2003 02:34 PM
Copyright 1999-2017 diyAudio
