Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 25th October 2010, 03:33 AM   #101
billo44 is offline billo44  United Kingdom
billo44's Avatar
Default Found it
I'll answer my own question.... The transformer PN# is correct.
It's right there on Okapi's pdf... sorry folks!
Bill
Old 26th October 2010, 11:37 AM   #102
johnm is offline johnm  United Kingdom
johnm's Avatar
Hi folks.
I was wondering if anyone had had any success in quieting down the Sanyo mechanism? Indeed my only complaint with Shiga (with Peter Daniel's superb chassis) is the noise from the mechanism. Shiga is positioned about 2M from my listening position (which I cannot change) and it really is quite audible on quieter music.
Does anybody know where the noise comes from? I have a feeling it's whatever the motor spindle is resting upon when it rotates. Was wondering whether this can be improved with a teflon thrust pad or something? I may try and get a donar motor and take it apart to see what makes it tick, and if it can be improved.
- John
P.S. I've also noticed quite a variablity between the Sanyo transports. i.e. some of them play anything you throw at them, others have problems with some CD-Rs or reading the red-book layer of SACDs etc.
Old 26th October 2010, 12:41 PM   #103
billo44's Avatar
Default noise
I just purchased a second Sanyo WPC boombox.... stripped it and found the laser unit and board to be much cleaner and better assembled than the first one I purchased. And...
Not a surprise to me, it sounds better too!
Budget items like this don't have enough profit margin built in for any kind of rational quality control.
Like you John, I notice the noise from the motor/spindle/disk/puck arrangement which is actually turning the disk. I was noticing some disks make more noise... warping perhaps?
I am at a loss as to why we DIY folk can't use brushless motors and hall sensor based speed controllers for audio, all tried and tested existing technology for PC CD ROM drives (and radio control, another marginal hobby (of mine))... just need to get a good direct output to audio without sticking a computer in between.
Any mechanism spinning at speed needs to be properly balanced and I personally think the cheap magnetic puck is the weakest link here.
It doesn't centre in the same place every time for a start.
Just watch it from the side and you will see what I mean.
I tried to PM you John M to ask for your current capacitor preferances for power supply and C916?
Any advice or opinions on readily available capacitors folks?
brgds
Bill
Old 26th October 2010, 02:05 PM   #104
johnm's Avatar
Hi there!
Sorry yeah turned off my PMs a while back and have forgotten to re-activate it.
I went with x2 Rubycon ZL caps (many prefer them to Black Gates and they use a more modern 'recipe' from the same manufacturer) from Farnell UK in the end, along with the recommended 7808 regulator. For the main drive board I followed Peter's advise on only taking out C916 and C952 (plus the ceramic bypasses), and replacing with one Black Gate N 47uF/50V for C916. Like Peter, I discovered with my original experiments using my first mechanism, that the supplied caps work VERY well in the circuit and are best left as-is, apart from the above two exceptions.
Was wondering whether replacing the cap-rectifier-cap with a TeddyReg (or similar) would reap any additional benefits? I'm a firm believer in the PSU being the heart/foundation of any decent hi-fi component, and many rave about the benefits of these regs. May well try one when the funds are looking a bit healthier
http://www.teddypardo.com/ (Click upon DIY on the left, then SuperTeddyReg)
Agree about the puck - I also think it's probably a tad too heavy for the mechanism too. Using a bit of blutac works very well, though obviously doesn't look too great. I'd love to get a proper screw puck manufactured from frosted acrylic or something similar.
Regarding the motor, I'm wondering if one can purchase higher spec versions in the same series which would just be a simple replace and fit job on the Shigaclone? Brushless would be good. I've noticed on one Sanyo mech the motor is free to rotate if one brushes the CD with a finger. The turn is smooth. I have another where it seems to go around in 'stages' if that makes sense? Like it's jumping from one pole to the next around the circumference?
Lastly, I found the transport can sound quite 'dry' when used freshly modded. Needs a few days to really come on song. Possibly due to that Black Gate.
- John
Old 26th October 2010, 07:20 PM   #105
johnm's Avatar
P.S. The Rubycon ZLs where 1000uf / 50V types.
Old 26th October 2010, 07:58 PM   #106
johnm's Avatar
Sorry! 1000uf / 25V.
Got there in the end
Old 1st November 2010, 04:46 AM   #107
billo44's Avatar
Default on the bench
Thanks for the advice John M.
Well I had a good weekend 'fiddling with my knobs' as my family call it (bless the little dears!)....
Haven't received any of the Caps I have on order yet, but just with what I found locally it sounds fairly good! Running off my DC bench supply for now (it's a pretty good one I got ridiculously cheap)...
I found out how to fix the noise from the drive itself... turn the music up!
Same principle as dealing with irritating rattles in the car.
Joking aside now, it seems quieter strapped-down to a piece of cast iron griddle, I would like to seperate the mechanism from the boards, but getting the laser sledge stop reed switch in the right place seems like it would be tricky. The switch is fixed to the board as standard
How critical is that switch positioning anyone?
Bill
Old 8th November 2010, 09:18 AM   #108
iwok is offline iwok  Poland
I am just biulding my own shigaclone. Already have a PS according to Peter`s design. I know this may sound silly, but could someone tell me how to connect it to the main transport board? Should it be this way or the other way round? The last thing I would like to do is burn my precious Ez31
Thanks in advance.
Old 8th November 2010, 11:57 AM   #109
Thanks in advance.
u have got it reversed (wrong way). u need to swop them around.
Old 8th November 2010, 01:12 PM   #110
Thanks commstech.
Just found out how to use multimeter to check polarity
CD PRO 2 - The making of a high end CD Transport Peter Daniel Digital Source 439 12th January 2010 08:09 PM
Wanted: Leftover DAC from an upgraded CD player, or CD player with broken transport. Spasticteapot Swap Meet 0 7th October 2006 08:12 PM
CD Player vs. CD Transport using CD-PRO2 module tomchaoda Digital Source 27 22nd May 2004 08:29 AM
CD-ROM as a CD Transport ruangrit Digital Source 4 29th April 2003 01:34 PM
Copyright ©1999-2013 diyAudio
