Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 9th December 2009, 08:10 AM   #1
Plammox is offline Plammox  Denmark
Default Bridged LM4780 kit: 5 Ohms (Min) at 300Hz = smoke?
Hello all (and Peter in particular)
I'm in the process of building a pre and a power amp and procured most of the parts including the LM4780 kit. Now, since I'd like to take advantage of the balanced output of my preamp, meaning I want to bridge the LM4780s and run them in balanced mode.
Now, the loudspeaker kit that I'm planning to get (Jantzen audio MTM kit) has a minimum impedance of 5 Ohm @ 300Hz.
The application note AN-1192 from National claims the BR100 config can drive a 4 Ohm load (@ +-20V supply). Is this completely analogous to the balanced configuration option of the LM4780 kit?
Best regards,
Lars
Old 9th December 2009, 10:10 AM   #2
a 3886 and half a 4780 is shown to give 35W into 4r0 when fed with +-20Vdc.
When bridged (balanced) this gives 70W into 8ohms.
To take account of voltage sag in your power supply the quiescent supply voltage is likely to be ~+23Vdc.
Each half of the bridged amp will dissipate a maximum of 27W and typically >10W during normal listening.
That means your 4780 chip must dissipate >20W normally and <=54W at worst case conditions.
That will require a big heatsink if you don't want Spike to cut current transients when the chip is hot.
regards Andrew T.
Old 9th December 2009, 12:00 PM   #3
Hi Andrew and thanks for your answer.
<=54W for a component in such a small package that on top has to be electrically isolated from the chassis seems like a bad idea. A more compelling option seems to be bridging two parallel coupled LM4780 boards for one balanced channel.
Are there any examples of people having done so with the Audio Sector kit?
Lars
Old 9th December 2009, 02:40 PM   #4
...or (I didn't really describe it correctly above) having two LM4780 boards each in parallel configuration, but each board running complimentary to the other (balanced mode), meaning one board providing the "forward" current and the other one sinking it.
Is this completely mad? Constructive feedback (even if the idea is barking mad) is appreciated.
Old 9th December 2009, 03:11 PM   #5
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I've been using bridged LM4780 for years in my workshop system with Audio Technology drivers:Flexunits 5 H 52 15 06 SD
As you can see, there is not much heatsinking in my simple chassis, yet with moderate sound levels, or really pushed for a reasonable period, it does not create any problems.
Without trying simple balanced configuration first, I would strongly discourage you from going into complicated and questionable from sonic standpoint parallel/bridged configuration.
You always have a choice taking advice from people who actually build that stuff, or merely theorize about specs
More info about bridged configuration can be found here: AudioSector-chip amp kits, dacs, chassis
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 10th December 2009, 03:44 PM   #6
Exactly. Which is also why I addressed you, Peter.
On closer thought, I think my choice of speaker kit is the problem. This being my first power amp I will build it, run the MTMs at low output power and build some bigger iron bigger next time
Thanks,
Lars
Bridged LM4780 Amp jackinnj Chip Amps 17 24th March 2011 04:36 AM
Bridged ClassD 800W in 4 ohms - oscillation problem Zoors Class D 24 10th May 2008 07:16 PM
Lm4780 Bridged PCB Baracus Chip Amps 8 7th January 2006 12:45 AM
Trying to understand the LM4780 bridged amp... youyoung21147 Chip Amps 27 23rd October 2005 07:41 PM
Bridged lm4780 rs1026 Chip Amps 2 12th September 2004 10:49 AM
Page generated in 0.07714 seconds (85.10% PHP - 14.90% MySQL) with 11 queries
