diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Audio Sector (http://www.diyaudio.com/forums/audio-sector/)
-   -   Kit arrived (http://www.diyaudio.com/forums/audio-sector/155635-kit-arrived.html)
littlerick 25th November 2009 01:22 PM
Kit arrived
Woo Hoo its here... Soon as I stop shakin with exitement I'll get started.
Just gotta find the thread that shows me how.
Thanks Peter. kit looks cool
Peter Daniel 25th November 2009 03:43 PM
2 Attachment(s)
You will find description of possible configurations here: http://www.diyaudio.com/forums/audio...tml#post636565
Amp and PS as per attached schematics. The yellow foils strip inside schematic sheet supplied with a kit is for chip isolation from a heatsink.
For more general info on amp building please refer to this thread: http://www.diyaudio.com/forums/audio...tructions.html (Please note that the diodes on LM4780 PS board are installed opposite to LM3875; just observe white stripes marking metal tabs orientation).
If you need more specific info, please post questions here.
littlerick 25th November 2009 05:58 PM
Ok I'm all set to go, Ive stopped shaking and have finished harrasing Peter via PM, thank you for all your help.
littlerick 25th November 2009 06:57 PM
Got the 1st three 22k ones in... Are these next two the right ones?
I have written what I think the values are, please correct me if im wrong.
http://www.pict.com/view/2055841/0/picture004
littlerick 25th November 2009 09:42 PM
I have soldered these into place but still not sure if its right...
I'm gonna join the bridges between boards coz I can do that bit.. I'm still not sure about other resistors ID yet. All the pics I can find look like different parts in places to what I have. Chill for a bit, try again soon.
Peter Daniel 25th November 2009 11:19 PM
1 Attachment(s)
This is how the resistors should be installed for parallel configuration. Please note that R0 is intentionally omitted. Also ad the jumper and Rm as pictured here: http://www.diyaudio.com/forums/attac...lel-bottom.jpg
littlerick 25th November 2009 11:27 PM
Sweet.. just gotta put the large ones in now.
I will put a picture up when I've got them done... This is my first ever time soldering a pcb so its taking me a little longer than most.
littlerick 25th November 2009 11:33 PM
MUR's??? The ones I see are the same way I've put mine in, but I notice that on other pics the flat metal side is towards white line, mine are opposite way. Have I looked at wrong kit and got it back to front?
Peter Daniel 25th November 2009 11:37 PM
Originally Posted by Peter Daniel (http://www.diyaudio.com/forums/showthread.php?p=1992619#post1992619)
Peter Daniel 26th November 2009 12:09 AM
1 Attachment(s)
So to be clear, the diodes in LM4780 kit install as pictured:
Copyright 1999-2017 diyAudio
