Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 3rd May 2014, 03:18 AM   #21
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Kit arrived Send a message via AIM to Peter Daniel
Input ground is connected with output ground on the board, however, they are run as two separate connections to the board (SG and OG pads)
Originally Posted by soundnovice View Post
i have 25-0-25 Vac (250VA) rated toroidal transformer. after rectification it will give 35.35Vdc. will this be ok for LM4780 amp in any of the mode?
Yes, that transformer is fine.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 27th December 2014, 05:35 PM   #22
NaveenPunnana is offline NaveenPunnana
Hi Peter,
I am new to this forum and i am interested in building a multi channel speaker system with LM4780 chips. Can you please suggest what should be the transformer that will be sufficient to power up all the chips. Below are the details of the system that i am planning to build.
No of satellite channels : 5 or 7 (60W)
Subwoofer : 1 (120W)
Currently i am on my way to collect some data.
Planning to use 30v-0-30v 5 Amp.
I already have 4 10000uf 63v caps.
Naveen P.
Old 2nd January 2015, 05:10 PM   #23
It's not an easy answer and the choice depends on how you want to manage chassis build and overall practicality of the system. You may go with a separate transformer for the sub and additional two amp channels and power all the other channels from a second transformer.
www.audiosector.com
Old 27th June 2016, 04:53 PM   #24
Tac Elf is offline Tac Elf
Peter,
For those of us who are red/green color blind, could you post separate schematics for the different configurations?
Old 20th August 2016, 06:37 PM   #25
Originally Posted by Tac Elf View Post
Peter,
That info, with pictures, was posted here: AudioSector-chip amp kits, dacs, chassis
www.audiosector.com
Kit arrivedHide this!Advertise here!
ZV4 has arrived. Nelson Pass Pass Labs 76 8th October 2014 04:04 PM
New toy has arrived! I_Forgot Digital Source 0 1st February 2008 01:57 AM
Its arrived Madmike2 Multi-Way 7 17th September 2005 03:53 AM
Just arrived marcograziano Introductions 1 16th December 2004 12:52 PM
New parts arrived & will foloow with kit, !!!!S1 12pcs arrived from Holland!!!! tube-lover Swap Meet 1 4th September 2004 12:29 AM
