Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 21st October 2009, 01:49 PM   #51
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
The Phono Stage Send a message via AIM to Peter Daniel
The phono stage has 47R output impedance and will work perfectly fine with 10K attenuator.
To order kits contact me through forum mail.
Old 30th October 2009, 04:08 PM   #52
toufu is offline toufu  United States
Hi Peter, I built the phono amp yesterday and can't get any sound out of it. I am getting +/- 15V from the regulator so I am assuming it is OK. Can you help me debug by providing some measuring points?
I think I connected it correctly, I jumpered the 4 places where marked. What are they R marking on the caps on the board for? I soldered the caps to the R point and to the other side, is that correct?
Anything else you can think of would be appreciated. Thanks!
Old 30th October 2009, 05:26 PM   #53
There are 4 jumpers from PS to phono stage and another 4 jumpers on phono board itself. Check if you have -15V on pin 4 and +15V on pin 7 on all chips.
If R7 isn't installed, the output is taken directly from C2 pin.
What DC offset are you reading?
The R indicates red lead on a V-Cap.
Old 30th October 2009, 06:13 PM   #54
mikebarney is offline mikebarney  United States
Default Jumpers
I'm (slowly) in the process of building this preamp as well. Regarding the jumpers on the phono board (not the jumpers from the power supply section), note that there are 2 silkscreen lines indicating where the jumpers go on the top of the board, and the other two silkscreen lines are on the bottom of the board. You'll note in Peter's photos, however, that he has all 4 jumpers on the bottom (not that it matters).
Mike
PS I'm now working on the heatsinks...
Old 30th October 2009, 06:19 PM   #55
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
I am using an original Kondo Audionote (Japan) Io cartridge which has a very low outputm - around 0.05mv and an impedance of about 2 ohms. It needs a lot of help! Can any configuration of this amp handle this small a signal reasonably well?
Many thanks.
Old 30th October 2009, 10:06 PM   #56
You would need a version with 90dB of gain. This is possible with this circuit, although I never tried it.
I'm starting building another unit with which I will experiment more.
Old 30th October 2009, 10:13 PM   #57
Here, how the jumpers should be installed on phono board. Make sure they are clear the traces underneath. If you prefer to mount them in a top layer, it's fine too, although they might interfere with the caps.
For this board, I'm starting with the transformer, as I want to measure all voltages step by step. So, the 48VA Hammond 229D24 (rated 2x 12V AC) produce actually 15.4V AC (my mains are 124V today), which is quite suitable for the planned 15V regulator output.
Please note the pcb mount fuse and 2 jumpers which set transformer's primary for 115V. For 230V mains only one jumper need to be installed.
Old 30th October 2009, 10:38 PM   #58
You can use both DIL and SMD op amp packages. With SMD, some pins need to be trimmed so they not interfere with pads nearby.
First picture shows op amps in PS section: top left pin is cut off completely and top right slightly trimmed.
Second picture shows opamp in phono section, here both bottom pins are cut off.
Old 31st October 2009, 03:40 AM   #59
I next install rectifiers and main filter caps. MUR860 is my preferred diode but of course other types can be tested here as well and to make things easier I marked pads with K and A. BG STD 1000/25 work very well as main filter caps in a phono circuit (better than any other BGs). Alternately, Panasonic FC or Elna Silmics could be also considered.
I'm getting approx 19V DC after smoothing and under full load.
Old 31st October 2009, 04:02 AM   #60
The biggest problem for me was finding suitable heatsinks, as none of the ready made solutions, which fit properly here, were efficient enough. Using enclosure to dissipate heat was of course my main goal when designing that board, and it works fine, but not everybody wants to place this circuit into an aluminum tubing.
I think I got a break today, when I figured out easy to fabricate custom heatsink: I simply use a section of 1 x 1 x 1/8 aluminum tubing and cut to 1.1" length with an opening on one side to mount devices. Additional access and mounting holes were also added. So far, this seems to work quite efficient and fits well
The Phono StageHide this!Advertise here!
NS-10 phono stage ponger Pass Labs 9 28th March 2011 08:57 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
phono stage east electronics Tubes / Valves 20 24th March 2008 08:22 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
