Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 1st October 2009, 05:44 PM   #41
toufu is offline toufu  United States
Trying to gathering up the parts for a build. Can C3 (10uf 50V) on the phono board use 35V caps?
Old 1st October 2009, 05:55 PM   #42
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
The Phono Stage Send a message via AIM to Peter Daniel
Any voltage rating on that cap will do fine
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 1st October 2009, 09:10 PM   #43
hayenc is offline hayenc  United States
hayenc's Avatar
Send a message via Yahoo to hayenc
The challenge is the 1k69 resistor. Caddock standard is 1k62. Only one I could find with that value is Holco.
Old 1st October 2009, 09:23 PM   #44
Percy carries 1K62 Caddocks, but this value does not seem to be critical?
www.audiosector.com
Old 1st October 2009, 09:27 PM   #45
hayenc's Avatar
Did not think it too critical, but Percy is away until mid-Oct and wanted something to put in the circuit. Will order from him when he is back.
Old 1st October 2009, 10:31 PM   #46
ahaja is offline ahaja  Poland
ahaja's Avatar
Ideal value is 1596R - instead of 1k62.
You cannot change it to other value because you change RIAA.
K
Old 7th October 2009, 10:14 AM   #47
Tarasque is offline Tarasque  Netherlands
Tarasque's Avatar
Hi Peter,
The phono project looks great!
Would this phono amp also be able to handle MC cartridges directly?
Also your board accomodates the Hammond transformer. Could I buy this one from you as well? (would save a lot in transport costs)
Thanks...
WWW.DelftAudio.com
Old 7th October 2009, 01:38 PM   #48
This circuit is designed to handle MC cartridges directly. I've been using it with Shelter 901 and did a lot of tests with ZYX Universe.
www.audiosector.com
Old 7th October 2009, 01:55 PM   #49
I can also supply transformer, but airmail shipping to EU would cost you additional $20
www.audiosector.com
Old 20th October 2009, 03:17 PM   #50
Longbow is offline Longbow
Default Attenuator value
Peter,
I'm interested in building one of your phono stages and it will be driving a passive attenuator. What input impedence would you recommend? The attenuator output will be driving an active x-over which was designed for 10K impedence. I'm wondering if I'll need a buffer.
Thanks in advance.
The Phono StageHide this!Advertise here!
NS-10 phono stage ponger Pass Labs 9 28th March 2011 08:57 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
phono stage east electronics Tubes / Valves 20 24th March 2008 08:22 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
