Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 7th April 2013, 03:23 PM   #411
BigE is offline BigE  Canada
BigE's Avatar
Originally Posted by ahaja View Post
Ideal value is 1596R - instead of 1k62.
You cannot change it to other value because you change RIAA.
K
A 110K ohm in parallel with the 1K62 will give you very close to 1K596 (1K596448). That should be close enough.
Old 16th June 2013, 10:45 AM   #412
Tarasque is offline Tarasque  Netherlands
Tarasque's Avatar
I've build this project and it does sound wonderfull. However I'm struggling to get rid of the humm.
Even more strange...when I mount the PCB in the alu tube, the humm increases.
Any suggestions where I could start looking?
Played with various grounding points for the grounding cable of the turntable and got the hum down but there is stull an audible hum when listening to vinyl.
Thx
WWW.DelftAudio.com
Old 18th June 2013, 05:53 PM   #413
BigE's Avatar
For the TT ground, I used an insulated speaker post that does NOT touch the chassis.
The chassis is connected to earth/safety ground through one of the PCB standoffs. You must use a metal standoff for this.
The speaker post is connected to power supply common on the RIAA circuit board, not the chassis.
I have no hum at all.
Old 21st June 2013, 02:23 PM   #414
Tarasque's Avatar
Well...This IS how I've connected the grounding.
I'm in the dark as to where I need to look next
WWW.DelftAudio.com
Old 28th June 2013, 03:20 PM   #415
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
The Phono Stage Send a message via AIM to Peter Daniel
Does the preamp humm without source connected? Maybe try different interconnects?
To order kits contact me through forum mail.
Old 28th June 2013, 04:08 PM   #416
Tarasque's Avatar
I've disconnected the amp bd from the PWR supply and made a copper casing for the amp. I've checked the output voltage and its clean.
When disconnecting the input I just get a bit of noise (no hum). When I connect the turntable I get a 100hz hum. That is strange to me because I would expect a 50hz hum when the turntable is picking up mains hum.
i use a SME20 / SME-V with Ortofon Rohman
When I disconnect the ground wires from the turntable, I get a bit more hum, but that is 50Hz hum.
100Hz hum would indicate a power supply / after rectification issue but the voltages are OK and I cant see any hum on the output with my scope.
WWW.DelftAudio.com
Old 28th June 2013, 06:30 PM   #417
BigE's Avatar
Unrelated quiestion:
Does the phono section work with a step up transformer?
Old 28th June 2013, 07:19 PM   #418
Tarasque's Avatar
I see no reason why it shoudn't. The only thing that could be changing the interface to the phono is the much larger output impedance of the stepup.
WWW.DelftAudio.com
Old 10th July 2013, 01:10 PM   #419
Tarasque's Avatar
Furher to my humm issue. Today i connected my phono board to alkiline batteries (2x10 AA) = 15-0-15V. There was no hum what so ever.
Question now is: Would this be a ground loop issue or a power supply issue?
WWW.DelftAudio.com
Old 6th August 2013, 06:25 PM   #420
BigE's Avatar
Does anyone know the deviation from RIAA equalization for this stage?
The Phono StageHide this!Advertise here!
NS-10 phono stage ponger Pass Labs 9 28th March 2011 08:57 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
phono stage east electronics Tubes / Valves 20 24th March 2008 08:22 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
