The Phono Stage - Page 4 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 28th September 2009, 05:29 PM   #31
chrismercurio's Avatar
Originally Posted by Peter Daniel View Post
I wasn't much into vinyl myself and I always though that well done digital playback system can equal analog. After listening to this phonostage in a well assembled analog rig (modified Versa Dynamics with ZYX Universe silver) I now simply don't think it's possible: the vinyl is so much better
I agree. It's not even close. Better yet? Tape!
Old 28th September 2009, 05:31 PM   #32
Originally Posted by woodturner-fran View Post
mmm. 5 phonostages is just excessive!
Not if you have a mix of 5 different stereo and mono carts and 5 tonearms set up on two TT's...just saying.
Old 29th September 2009, 12:21 AM   #33
toufu is offline toufu  United States
I have a Zu Denon 103 that I would like to try with it. But I also have a couple of nice MM cartridges.
Just out of curiosity, can I reverse the input/output on my step up transformer so that I can lower the gain of my MM cartridges and make them work with MC phono amps?
Old 29th September 2009, 12:25 AM   #34
Nah, well you can only listen to 1 at a time. I've 2 pretty good ones, 2 ok ones so I could use 4 I suppose!!
What I say next might be controversial: but I think its very very hard for a MM cart to meet and beat an MC one. Even the cheaper MC ones seem to have a clarity to them that the MMs just can't surpass. Actually might post a poll on that one!
Fran
Old 29th September 2009, 06:23 AM   #35
The Clearaudio Maestro Wood is a very nice cartridge. I'm not going to say it beats a Miyabe or a Koetsu RSP, but it is very balanced and doesn't require an incredible phono stage to sound good. Threadjack over.
Old 29th September 2009, 06:25 AM   #36
Transformers work in both directions. They aren't gender biased and don't discriminate against input voltage and current AFAIK.
Old 29th September 2009, 07:43 AM   #37
cyxg is offline cyxg  Australia
It is for MC with 75dB gain.
hi, peter
you kit is for MC only?
Specialist in machinery technology-HOBBY&DIY
http://www.greatinfo.com.au/
Old 29th September 2009, 01:12 PM   #38
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Yes, indeed.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 30th September 2009, 01:03 AM   #39
I have a nice MM cartridge that has an fairly low output of 1.5 - 2mv. Is that too high for the phono amp? Also, 0 ohm inpedence, does that mean it will match with any cartridge?
Old 30th September 2009, 01:26 AM   #40
"Most of MC cartridges available in the current market are compatible. Since it is a current amplification device with 0 ohm input impedance, output level is determined by the output amperage of the cartridge (output voltage divided by internal impedance)"
www.audiosector.com
NS-10 phono stage ponger Pass Labs 9 28th March 2011 08:57 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
phono stage east electronics Tubes / Valves 20 24th March 2008 08:22 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Copyright ©1999-2017 diyAudio
