Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 11th January 2012, 05:04 PM   #361
BigE is offline BigE  Canada
Originally Posted by tms0425 View Post
I had one wire from each phono board over to the insulated ground terminal. TT ground was connected there.
Where is is attached on the phono board? Mine is attached to the GND side of the two caps on the phono circuit. See Peter's photos on post #1
Old 15th January 2012, 07:58 PM   #362
freebee is offline freebee  France
Default Ordering Phono Kit
Is it possible to order the full kit through Audiosector?
Old 17th January 2012, 09:35 PM   #363
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Send me an email for current price list.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 18th January 2012, 05:27 AM   #364
Smile The Phono Stage kit
Thanks Peter. I've just sent you an email via your Audio Sector website.
Old 28th January 2012, 12:55 AM   #365
No change.
Here is what I did tonight:
- Removed both black phono board ground wires from black ground terminal and also separated them from each other (floated)
- Removed TT ground from isolated black ground terminal (floated)
- Removed AC power to the TT
- Removed AC filter board and input circuitry from the back right of chassis
- Hardwired AC directly to the 2 power supplies in front of the chassis. IEC is fed there to the front instead of the back right.
- Re-dressed all cables to ensure they are separated away from AC sources
There was no change at all from these steps. One channel slightly more hum than the other, but not much. Basically gain is fairly high, to the point where hiss is starting to be evident when the hum starts.
When I remove the input cables from the preamp or remove the headshell all is quiet, which I suppose makes sense. This old Empire tonearm cable and arm wiring does not have any shielding or a separate ground on it. The ground wire from the TT is tied to the plinth/chassis itself, a few inches from the arm base. I have a new TT and tonearm on the way so will replace that very soon.
I guess it's time to separate the power supplies from the phono boards, recheck soldering, and see what happens. It's just a pain because they're both hardwired.
The strange thing is I actually built up a PhonoClone3 without a case and I have a stock Jolida JD9 and neither of them hums with the same TT/arm.
I don't really have any particular advice here, as it seems like the problem is system dependent, however, this is what I observed today in my setup:
I've just built a preamp for a customer and was testing it before shipment. The unit was built exactly as pictured ion a first page of this thread. Chassis is grounded through the earth pin on a power entry module, RCA jacks are isolated from a chassis. I'm using Shelter 901 mounted on SME V tonearm.
There was initially low level hum at maximum volume level on a TVC based preamp. After ground wire from TT was connected to the chassis or one of the RCAs, the hum disappears.
www.audiosector.com
Old 28th January 2012, 01:46 AM   #366
tms0425 is offline tms0425  United States
Thanks Peter. I hope to get back to this problem this weekend. I tried to follow my usual common sense grounding rituals but there still seems to be a little special magic to get it all worked out sometimes. I have a whole new TT/tonearm setup now. It has a slate plinth so there isn't even a metal chassis to ground to other than the tonearm base and the bearing. I'll experiment a bit and see what happens. Hopefully it follows some logic this time ;-)
Tom
Old 28th January 2012, 02:25 AM   #367
When I brought my phono stage to a frieds place, they hummed a bit. Making a better groung connection than an alligator clip solved the problem.
Old 31st January 2012, 07:29 PM   #368
I switched to the new TT and arm, and to a Zu Denon 103 instead of the 103R which has a lower resistance. Hum is significantly less now, even just using a nest of clipleads to experiment with. Hopefully I can get past it now. Thanks for help.
Tom
Old 21st February 2012, 04:41 AM   #369
eelind is offline eelind  France
Hi Peter. Nice job. When thé LM3875 Will be finished, I think I Will Troy your phono stage. One question: did you think about using an RLC RIAA corrector instead of the R and C network?
Eric
Old 23rd February 2012, 04:25 PM   #370
If something works good, I prefer not to touch it
www.audiosector.com
NS-10 phono stage ponger Pass Labs 9 28th March 2011 08:57 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
phono stage sakis Tubes / Valves 20 24th March 2008 08:22 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Page generated in 0.08506 seconds (74.03% PHP - 25.97% MySQL) with 11 queries
