Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 27th September 2009, 05:25 PM   #21
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
It's best to order them directly from the source: http://www.v-cap.com/tefloncapacitors.html Notice the discount for 2pcs or more.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 27th September 2009, 05:33 PM   #22
hayenc is offline hayenc  United States
hayenc's Avatar
Send a message via Yahoo to hayenc
Worked great. Thanks Peter.
Old 27th September 2009, 05:37 PM   #23
And don't forget to break them in
http://www.diyaudio.com/forums/parts/152329-breaking-teflon-caps-post1931175.html
Although I never did it with mine; they seem to work fine right from the start.
www.audiosector.com
Old 28th September 2009, 02:06 AM   #24
cyxg is offline cyxg  Australia
Originally Posted by Peter Daniel View Post
I'm sourcing MJE1530x from Digi Key. All op-amps have SMD pads already.
beautiful PCB!
Specialist in machinery technology-HOBBY&DIY
http://www.greatinfo.com.au/
Old 28th September 2009, 02:36 AM   #25
toufu is offline toufu  United States
Peter, what's the gain for the phono amp? Is it for MC or MM?
Old 28th September 2009, 02:58 AM   #26
It is for MC with 75dB gain.
www.audiosector.com
Old 28th September 2009, 04:43 PM   #27
Is it easy to modify the circuit to lower the gains to work with MM cartridges? Or are you planning to design an MM version of the circuit?
Old 28th September 2009, 04:55 PM   #28
chrismercurio's Avatar
I doubt it...
Peter's original postings indicate that it is his version of the Phonoclone which in turn was inspired by the 47 Laboratory Phonocube. The low gain version of the Phonocube is 75db, the high gain is 90db and the overall gain achieved is wholly dependent on the cartridge impedance.
You can read about it here:
http://sakurasystems.com/products/47phono.html
but the details are sketchy. I had a Phonocube for a year or two about 8-9 years ago and it remains in my mind as one of the best sounding phono stages I have ever heard. It was also the quietest which is a big deal as far as I'm concerned.
Old 28th September 2009, 05:16 PM   #29
To be precised, it is my implementation of phonocube circuit. AFAIK, it is exactly same schematic, I'm just using different part choices and different PS. The circuit is different from the phonoclone popularized here, and based on some comments from people who built both, it's also better sounding. With proper selection of opamps, it does not require output coupling caps (offset stays below 2mV if you are lucky, on average it is below 10mV).
To get idea on the sound, you may read this review (of the original product): http://sakurasystems.com/reviews/reviews9.html
I wasn't much into vinyl myself and I always though that well done digital playback system can equal analog. After listening to this phonostage in a well assembled analog rig (modified Versa Dynamics with ZYX Universe silver) I now simply don't think it's possible: the vinyl is so much better
www.audiosector.com
Old 28th September 2009, 05:28 PM   #30
mmm. Now I'm just going to have to build this one. I've had a couple of iterations of RJMs phonoclone and also a pass pearl with lundahl step-ups so I think this would be a good one to add to that mix. Gonna have to sell some of the other though. 5 phonostages is just excessive!
Fran
NS-10 phono stage ponger Pass Labs 9 28th March 2011 08:57 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
phono stage sakis Tubes / Valves 20 24th March 2008 08:22 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Page generated in 0.08229 seconds (72.38% PHP - 27.62% MySQL) with 11 queries
