Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 4th July 2011, 06:24 PM   #281
BigE is offline BigE  Canada
BigE's Avatar
What an incredible setup. Obviously, I am in a disadvantaged position.... it is pointless for me to change anything. I shall go back to the copper signal wire, and repair the grounding.
I should spend some time making my setup look more like that setup. (A Technics Sp10 in a panzerholz/birch plinth is on the way, probably with the Benz Glider SL. Arm, as of now, is undecided.).
Old 5th July 2011, 04:52 AM   #282
BigE's Avatar
Update: I changed the signal wire to Legenburg upocc copper from Mundorf Silver/Gold 26awg.
The difference is enormous. The Denon 103D is ok now.
Don't use silver wire -- with silver the sound lacks body.
Old 5th July 2011, 03:49 PM   #283
fmena is offline fmena  Canada
Default Ground points
I have a similar problem in that as I turn up the volume I get more hum.
Presently I have the AC-IN and Turntable ground connected to a single ground- post on the chassis. I was wondering if I could connect the GND points I have coloured in red (see attachment photo) to the ground post mentioned above.
Also Peter mentions in Post 180:
You may try connecting wire from TT to the common PS ground at C4/C5.
Where in the heck is the common PS ground at C4/C5 on the PCB? Could someone spell it out for this dummy?
Thanks in advance.
Cheers
FM
Last edited by fmena; 5th July 2011 at 03:51 PM. Reason: Cut instead of copied text
Old 5th July 2011, 04:02 PM   #284
BigE's Avatar
Sure. I used a speaker post, but make sure you can solder to it. There is no connection to the chassis.
Also, I connected 3 holes over, to where the capacitors join -- the grounds you have labelled connect to the same place.
Old 5th July 2011, 05:11 PM   #285
BigE's Avatar
FYI: C4 and C5 are on the PHONO board side, not the PS supply side.
Old 5th July 2011, 05:30 PM   #286
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
The Phono Stage Send a message via AIM to Peter Daniel
It's the trace that connects pins of both caps, as indicated in attached pic.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 5th July 2011, 07:15 PM   #287
Carlp is offline Carlp  United States
As to hum, it looks to me like the mains ground leg is tied to one of the mounting posts, which might, depending on the build, also connect to the chassis. If you have another ground point tied to the chassis elsewhere, you've undone any "star" like grounding AND created the possibility of current flowing in the chassis and hum deriving there.
Old 5th July 2011, 08:55 PM   #288
Yes, the ground post should be isolated from the chassis and connected to the point indicated in my previous post.
www.audiosector.com
Old 6th July 2011, 02:53 AM   #289
BigE's Avatar
After fixing the ground and putting in the legenburg 24 awg equivalent copper, the unit sounds great.
Thanks Peter!
Old 12th July 2011, 02:03 AM   #290
BigE's Avatar
There are 80+ hours on the Vcaps and it's sounding better and better all the time. This is a long, but worth it, break in period.
The Phono StageHide this!Advertise here!
NS-10 phono stage ponger Pass Labs 9 28th March 2011 08:57 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
phono stage east electronics Tubes / Valves 20 24th March 2008 08:22 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
