The Phono Stage - Page 20 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 3rd June 2010, 01:11 PM   #191
kstagger's Avatar
thanks Peter - in my haste yesterday, I ordered some J511s from HK. Good news on the op-amp.
Old 13th June 2010, 02:55 AM   #192
hayenc is offline hayenc  United States
hayenc's Avatar
Send a message via Yahoo to hayenc
Finally finished my phono stage. Running a Benz Micro-Glider S with 0.8 mV output into it. I have to admit I did not think it would sound better than my PH-5, but it does. More transparent mids and much more control of the bass. Very nice project.
Old 13th June 2010, 05:21 AM   #193
chrismercurio's Avatar
Agreed.
Old 15th June 2010, 11:50 AM   #194
mbosko is offline mbosko  Yugoslavia
Hi
How to get box surface like this
Old 15th June 2010, 05:40 PM   #195
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
This is brushed and anodized; done by a local shop that specializes in this type of work.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 17th June 2010, 01:15 AM   #196
kstagger's Avatar
tested the power supply - V+ = +14.88 volts... close enough for me. However V- = -2.1 volts. Negative voltage feeding into U2 is fine at approximately -18vdc. Where do I start troubleshooting? I'll start digging into it again tomorrow when I can get a fresh look at it. Just want to make sure I didn't invert a component!
Old 17th June 2010, 01:43 AM   #197
Are you using C4: The Phono Stage
www.audiosector.com
Old 17th June 2010, 12:47 PM   #198
kstagger's Avatar
No I'm not - but I can add it. Thanks! On my parts list, guess I got confused on what could be taken out.
Old 18th June 2010, 12:37 PM   #199
kstagger's Avatar
adding C4 did the trick - now I just have to go over my soldering (I'm an old p2p tube guy!) as I have one channel with excessive gain and no bass. Probably just a blog of solder making a junction with something else in the feedback loop. Thanks again for your help.
Old 19th June 2010, 12:31 AM   #200
kstagger's Avatar
after much head scratching, I finally reflowed every solder joint on the 'strange channel'. Also found an op-amp connection that looked a little dodgy and added some more solder. Once I finished that - everything works.
Obviously my Dynavector 10X5 is not an ideal cart - but it's making music! Very fast and detailed phono stage. Now I just need a better cartridge... to be continued.
NS-10 phono stage ponger Pass Labs 9 28th March 2011 09:57 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 06:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 10:51 PM
phono stage east electronics Tubes / Valves 20 24th March 2008 09:22 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 07:41 AM
Copyright ©1999-2017 diyAudio
