Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 4th January 2010, 11:52 AM   #151
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
The Phono Stage
Here my own compilation of the complete parts list phono preamp and shunt regulator section with distributors, prices, etc...Maybe Peter can comment on its latest findings about the circuit to see if this list is still up to date. I included the omission of R7, output resistor of the preamp section.
Old 4th January 2010, 11:54 AM   #152
Algar_emi's Avatar
The Phono Stage
Old 4th January 2010, 02:05 PM   #153
Algar_emi's Avatar
The Phono Stage
Here an updated version, removed C3-C6 on the Shunt regulator as suggested by Peter.
Old 4th January 2010, 02:44 PM   #154
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
The Phono Stage Send a message via AIM to Peter Daniel
In majority cases C4 is still needed as most LM337 types will not produce correct voltage without it: The Phono Stage
To order kits contact me through forum mail.
Old 4th January 2010, 03:06 PM   #155
Also, while you specify Nichicon (Mouser 647-UES1H100MPM) for C3, the Wima MKS2 may be actually a better choice (when BG N is not available)
Old 5th January 2010, 04:38 PM   #156
chrismercurio is offline chrismercurio  United States
chrismercurio's Avatar
Peter,
Do you have a high gain version of this available? I'm not sure if it is just a few parts in the BOM that need to change or if it is entirely different.
Thanks,
Old 5th January 2010, 04:45 PM   #157
I was told that the gain can be adjusted with R2, R3 (3k3 presently) and of course by using cartridge with different internal resistance.
Old 5th January 2010, 07:48 PM   #158
Algar_emi's Avatar
The Phono Stage
Thanks Peter for the precision. SB
Old 3rd February 2010, 11:48 PM   #159
Peter,
A couple of questions:
1. What value is necessary for R2/3 to raise the gain to 90db?
2. IF using a battery supply, is it possible to eliminate caps C4/5? I couldn't find them in the schematic posted on the first page of the thread either.
Best,
Chris
Old 4th February 2010, 01:20 AM   #160
1) I really don't know, never experimented with gain.
2) It could be possible, but again, it needs to be tested. Even with batteries, I usually prefer to use some caps, but much smaller in value.
The Phono StageHide this!Advertise here!
NS-10 phono stage ponger Pass Labs 9 28th March 2011 08:57 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
phono stage east electronics Tubes / Valves 20 24th March 2008 08:22 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
