#141 |
Hi guys , just completed my phonostage-measured DC offset at 15/20mV-?any problem?
#142 |
Hello Peter, can you give some information about signal to noise ratio? Did you measure this ?
#143 | |
I didn't measure it, but subjectively it's very quiet. You may check this review of the original circuit (I use different parts and completely different PS): H A L L O F F A M E
The offset will depend on a particular OPA637 chip; some chips will produce much less offset.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#144 |
Sorry Peter, NOOB-GC?-what output coupling cap will be needed?
#145 |
Check the offset with the amp connected for different volume settings (speaker disconnected when testing). If it exceeds 100mV use 2.2 - 4.7uF coupling caps.
#146 |
Hi Peter, plugged in it today-the transformer humming and vibrating like crazy and feel as though not enough gain( compare with herron audio phonostage-66db)
The tranny was dropped onto the floor the other day!!! Likely to be faulty. Please advise how to wire with dual secondaries toroidal transformer. NOOB question. Thanks. |
#147 |
I'm using 2 x 12V transformer, which unloaded produce approx 14V AC per secondary.
In attached pic, you can see 4 pads (on a left). Those pads are for external transformer connection: first two from the top are for one secondary, the other two for the other secondary. You will need approx 19V after rectification and 15V regulated. If you can get 15V because of too low voltage on secondaries, settle for lower regulated voltage, it will not affect anything (adjust with changing R7 and R8)
#148 |
Hi peter, do the secondaries need to be in phase?
#149 |
As both positive and negative regulator circuits are completely independent, the secondaries do not need to be in phase; you can also use two separate transformers with single secondaries.
#150 |
Thanks Peter.
| Thread Tools | Search this Thread |
| NS-10 phono stage | ponger | Pass Labs | 9 | 28th March 2011 08:57 AM |
| DIY phono to replace roksan phono stage | seroxatmad | Analog Line Level | 6 | 14th December 2008 05:46 PM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 09:51 PM |
| phono stage | sakis | Tubes / Valves | 20 | 24th March 2008 08:22 AM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 06:41 AM |
