Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 28th November 2009, 08:55 PM   #121
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
The Phono Stage Send a message via AIM to Peter Daniel
In my recent build, I tried to reduce the length of the chassis to match pre-cut tubing I'm using for DACs. Normally, phono stage requires at least 9.5" enclosure length. By placing amp board over the power supply I was able to reduce the required length to 8" only.
To prevent possible transformer influence, I used mu-metal shielding.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 28th November 2009, 08:58 PM   #122
hayenc is offline hayenc  United States
hayenc's Avatar
Send a message via Yahoo to hayenc
Yep, that's the one. Just did not look closely at the board.
Old 28th November 2009, 09:12 PM   #123
Since I use regular IEC inlet here, I also added a power switch. The front has slightly different arrangement than previously, with addition of ground post.
www.audiosector.com
Old 29th November 2009, 07:56 AM   #124
quan is offline quan  Australia
Hi Peter , what fuse do you use?
Old 29th November 2009, 07:19 PM   #125
I use DK part# 507-1032
www.audiosector.com
Old 29th November 2009, 07:23 PM   #126
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Looks really good Peter,
One question, how come you have the power at one end and rca's at the other ? Wouldn't it look better if it was all on one side and a nice little Green power led on the front ? I know your trying to isolate the ac from dc and noise and interference right ? However isn't that all removed from the equation because it's in a metal enclosure ? have you tried putting the transformer/psu in another box with a umbilical cord ?
Just some thoughts and questions i had
Looks nice and sexy tho, always admired your machine work.
J'
Old 29th November 2009, 07:27 PM   #127
For me, form follows the function, besides, with such small end panels I can't fit all on one side.
Yes, I've build units with separate supply and phono amp modules attached directly to TT, built into interconnect; it works even better this way.
www.audiosector.com
Old 1st December 2009, 01:39 PM   #128
2A3SET is offline 2A3SET  Canada
Default Use LED as volt ref
Have you tried LED reference (normal one, not low current) instead of D11/D12?
I am using audio-gd shunt reg with VSPS.
Originally Posted by Peter Daniel View Post
I had a chance today to do some careful comparisons with PS and as suggested earlier, I did remove C3/C4 across current source: the sound become noticeably better without those caps (less coloration). I also removed C5/C6 and further improvement was observed. I tried without C9/C10 as well, but circuit actually sounded better with those caps in place. Nichicon FG was preferred here over BG STD, something I suspected already. BG N 10-47uF could be another good choice, although not that much better than FG.
I also did some testing with constant current regulator types. I really liked the old production ON Semi, National was second, then the new production ON Semi while Linear Technology LT317 was the worst; nice sound but too technical, ON Semi was OTOH much more musical.
Attached is updated PS schematic.
Old 1st December 2009, 04:08 PM   #129
I might try it this week.
www.audiosector.com
Old 1st December 2009, 07:36 PM   #130
jormajj is offline jormajj  Finland
the PCBs and parts kit arrived today. Thanks Peter
The Phono StageHide this!Advertise here!
NS-10 phono stage ponger Pass Labs 9 28th March 2011 09:57 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 06:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 10:51 PM
phono stage east electronics Tubes / Valves 20 24th March 2008 09:22 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 07:41 AM
