Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 21st August 2013, 01:53 PM   #71
aasing is offline aasing  Malaysia
still available?
Old 9th September 2013, 08:08 AM   #72
helfred is offline helfred  Denmark
Peter,
I was wondering if you would still have some boards on the shelf ?
Helfred
Old 11th September 2013, 01:30 PM   #73
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Universal Power Supply PCB Send a message via AIM to Peter Daniel
I presently have only negative voltage PS boards left, they can be easily modified to positive voltage though.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 1st October 2013, 09:03 PM   #74
Hikari1 is offline Hikari1  United States
Peter,
I have your boards. Trying to build a bipolar PS w/LM317-337.
Do you have a schematic of the board? Does it matter which spot (of the available two spots per board) the regulator IC (317/337) goes in?
These are very well made boards, BTW. There is so much copper in them I had to use my hi-power soldering iron on the supply caps.
Old 19th February 2015, 05:24 PM   #75
C37 is offline C37  Belgium
Peter, do you have any ps boards left? I've seen some are asking them in swap meet so maybe you are out of stock?
Ohm sweet ohm
Old 7th April 2015, 11:21 PM   #76
Frogeye is offline Frogeye  United States
Peter,
PSU boards still available?
Hal
Old 26th July 2017, 08:45 AM   #77
ZoSoNCSU is offline ZoSoNCSU  United States
Send a message via AIM to ZoSoNCSU
Peter, I sent you a PM, hopefully that isn't too much trouble. If nothing else, I can just get the normal kit and sell the extra amp PCBs.
BTW, what is the reason to run one of these vs. normal designs like you see on Amazon bundled with MX50 kits. This just looks funny having so many caps
Also is it worth it to have a kit with protection built in on the rectifier PSU module?
MUR860G Rectifier Filter Power Supply Board w Speaker Protection 50V/6800UF LED | eBay
I don't intend to buy either, but I am curious about their usage/purpose.
Universal Power Supply PCBHide this!Advertise here!
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
