| Audio Sector Kits & PC boards from AudioSector |
#61 | |
"Science is not a democracy"- Earl Geddes, Ph.D. |
#62 |
Hi Peter, any more PSU boards?
#63 |
Yes, I have them back in stock now.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#64 |
I sent an email for boards but never heard back. Do you have them still?
#65 |
Yes, the boards are still available.
#66 |
Looks like the diode boards only do 1 diode on a paralell dual TO247 configuration? Yea, run a jumper, 3 of 'em are easy and 1 has to fly. I know... I guess I need to spend hours searching or make my own, if I want both diodes with real high current connection, ha?? Save these for a pre???
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#67 |
For those boards to be truly universal there was no way to implement both diodes on a 3 pin package.
#68 |
Thanks Peter. I guess just making jumpers with descent sized buss wire and solder wouldn't be to bad. Less R than the wires from the xfrmr and to the caps. It just will look less than perfect
#69 |
Peter,
I was wondering if you would still have some boards on the shelf ? Cheers, Max PM? |
#70 |
| Split Voltage Switching Power Supply for Power Amp | vectorplane | Swap Meet | 2 | 23rd April 2011 11:48 PM |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| selling high current power supply for power amps. | ericpeters | Swap Meet | 0 | 14th January 2005 02:21 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
