Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 19th March 2011, 06:24 PM   #51
NYCOne is offline NYCOne  United States
Peter,
I'm thinkning of using an MUR3020, MSRF860 or MUR1520 with your rectifier boards for a balanced F5. What heatsinking do you use with these pieces?
Old 26th November 2011, 01:59 PM   #52
jtktam is offline jtktam  Canada
Peter,
for R2/R4, is there a formula to calculate the value needed for a certain output voltage?
thanks
-joe
Old 29th November 2011, 02:28 PM   #53
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Which regulator you have in mind?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 23rd January 2012, 09:27 AM   #54
Default Need a power supply board
Peter,
Need a power supply board for Pass F5 build. Let me know where to order and how to order.
Pandu
Old 23rd January 2012, 06:35 PM   #55
johnm is offline johnm  United Kingdom
johnm's Avatar
Hi Peter.
I wish to use my universal PCB I purchased a while back from you to provide 24V for a Pass Labs B1 buffer.
R1 = 240R
R2 = 5R adjustable
I'm using Black Gate Standard 1000uF/50V for the main PSU caps either side of the LM317 on your board.
Do I need to bother with C1/C2/C5 in your opinion?
Many thanks!
- John
Old 23rd January 2012, 06:54 PM   #56
I wouldn't bother with bypasses on main caps but would probably install 10uF cap across adjustable resistor.
www.audiosector.com
Old 23rd January 2012, 07:47 PM   #57
johnm's Avatar
Great - I'll do that! Thanks Peter much appreciated
Old 23rd January 2012, 09:13 PM   #58
johnm's Avatar
P.S. Sorry knew there was something else! Peter do you prefer using a CT transformer and a pair of diodes with your PSU board, or a non CT transformer and 4 rectifying diodes? Which is meant to be the best? Thanks
Old 19th February 2012, 04:48 PM   #59
Default ps boards
are these pc boards still available?
where can they be purchased?
thanks,
michael stevener
Old 19th February 2012, 05:02 PM   #60
I just run out of therm few days ago. Might get more in a future though.
www.audiosector.com
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.09124 seconds (76.63% PHP - 23.37% MySQL) with 11 queries
