Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 16th December 2010, 04:03 PM   #41
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Universal Power Supply PCB Send a message via Yahoo to vdi_nenna
Yes, it's recommended to connect center ground traces (red jumper in attached pic). That would be your power star ground where all other grounds are connected (also the chassis ground). Attached is also wiring diagram for F5 amp.
What are you guys using to connect all the grounds to a single point?
Soldering or some kind of post?
I build, therefore I am.
Old 4th January 2011, 02:59 PM   #42
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Universal Power Supply PCB Send a message via AIM to Peter Daniel
I use solid core copper jumper between ground traces.
To order kits contact me through forum mail.
Old 4th January 2011, 03:00 PM   #43
An interesting implementation of the regulated PS option can be found here: wavelengthbrickpowersupply - mpbarneysources
Old 5th January 2011, 09:45 PM   #44
danbmellow is offline danbmellow  Canada
How do I get a hold of the PCB's for this power supply?
Old 5th January 2011, 10:00 PM   #45
Contact me through forum mail.
Old 7th January 2011, 06:34 PM   #46
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I bought your Aleph J psu boards and PCB and have a question for you. Pass uses 120,000uf worth of caps in his psu, but you only have space for 2 possibly 4. what is the reasoning behind this? what caps would you suggest for quality implementation for the Aleph J.
Old 1st February 2011, 02:31 PM   #47
What is the reasoning? To use not more parts than necessary.
Attached is search result for compatible caps from digikey which are in line with what Pass uses (they are also rated more generously)
Old 1st March 2011, 03:21 PM   #48
vdi_nenna's Avatar
I used the universal power supply as a regulated +-15 supply using LM317 and it's compliment. To get the voltage to +-15v, I used a adjustible resistor. One of the legs on the pot is floating or not connected. I know it would be best to remove it, measure it and replace it with a resistor, but I would like to keep it in for now.
What should I do with the third leg of the pot that's floating? Leave it floating, ground it or attach it to the center pin of the pot itself?
Thanks,
Vince
Old 2nd March 2011, 01:02 PM   #49
Either attach it to center pin of the pot or replace the pot with resistor.
Old 10th March 2011, 08:26 PM   #50
nycavsr2000 is offline nycavsr2000  United States
nycavsr2000's Avatar
My Poseidon's Voice Katalyst PS uses Peter's board as well as a Paul Hynes' shunt regulator and has worked flawlessly for years.
Best,
Anand.
Universal Power Supply PCBHide this!Advertise here!
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
