Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 28th March 2010, 12:35 PM   #31
cjkpkg is offline cjkpkg  United States
What is the optimal grounding scheme for this PSU when used as V+/V- ? It is for an F5 amp.
Specificaly where is the best place to pick up the chassis ground? Best place to hook up the neg speaker terminals? Do the two center "ground" traces need to be jumpered together?
Thanks!
carl
Old 30th March 2010, 03:39 AM   #32
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Universal Power Supply PCB Send a message via AIM to Peter Daniel
Yes, it's recommended to connect center ground traces (red jumper in attached pic). That would be your power star ground where all other grounds are connected (also the chassis ground). Attached is also wiring diagram for F5 amp.
To order kits contact me through forum mail.
Old 30th March 2010, 11:58 AM   #33
Thanks Peter,
I essentially connected as you suggest with the exception of not using the jumper on the PSU board. I ran 6 independent ground leads from the GND of the PSU - one to each neg speaker terminal, one to each amp board, and two to the chassis(one from each side).
Everything appears to be functioning normally and the amp is quiet.
Old 11th April 2010, 03:15 PM   #34
lauret is offline lauret  Netherlands
lauret's Avatar
Originally Posted by Peter Daniel View Post
Now, for those who were wondering what are all those additional components for, here's the picture of the regulator circuit with LT1086. Of course this is no good for power amps, but works fine with preamps, active filters etc.
What kind of parts did you use in the regulator? I can only see the Nichicon (what value?) and the LT part...
Old 11th April 2010, 04:02 PM   #35
Just follow the datasheet: http://www.linear.com/pc/downloadDoc...55,P1358,D1722
The large caps in a pic are 4,700uF
Old 22nd June 2010, 01:20 PM   #36
Russellc is offline Russellc  United States
The rectifier section accepts high power diodes mounted as in a picture below (they can be attached directly to a chassis for heat dissipation, isolation pads needed). The board is designed mainly for 3 pin rectifiers, but will work with other diodes packages as well. Here's MUR3060:
I may have made an error here, you say isolation pads are needed? Nuts I used transistor grease and put them directly to the case. I guess I need to remove the grease and use isolation pads here then? I havent fire it up yet thank goodness!
Russellc
Old 22nd June 2010, 01:28 PM   #37
Depends on the rectifiers you use. The ones I use FOR MY F5 HERE do not need to be isolated.
I did not deploy the use of Peter's rectifier boards though. The Vishay rectifiers are cheaper and a little easier to use.
Old 22nd June 2010, 01:45 PM   #38
I uised the MUR 3060 and Peters boards
russellc
Old 22nd June 2010, 02:15 PM   #39
A-ha - yes you will need silpads or something. I started down that path and thought I would try the vishay units out to save some $$$ and they work fine.
Old 16th December 2010, 03:46 PM   #40
budwiser is offline budwiser  United States
Peter, How would I utilize your power supply boards for the Pass Pearl 2 that I am building.
Universal Power Supply PCBHide this!Advertise here!
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
