Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 25th September 2009, 02:54 PM   #11
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Jensens would probably be the top grade option, although a bit expensive.
Nichicons KG Super Through would be my next choice.
For other board options, use regulators datasheet and use recommended components. Here's one such schematic from LM317 datasheet.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 18th October 2009, 03:04 AM   #12
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Peter or anyone,
Do the TO-247 rectifiers need isolation from the chassis?
thanks,
Vince
Zen, BOZ, BOZ-J, BLS, B1, Mini-A, Audio Sector NOS DAC, Gain Clone, F5, CAT5 Speaker Cable, DIY Allen Wright ICs, MOX II
Old 18th October 2009, 09:02 AM   #13
fff0 is offline fff0  Singapore
Hi Peter, what do you think of Epcos SIKOREL?
Hi Vince,,
I suggest you take a look at the datasheet, if the back its connected to any of the pins, cathode or anode, yes it needs to be isolated.
Old 21st October 2009, 02:47 PM   #14
I don't have much experience with Sikorels. Used them only once in a PS and they seemed fine.
www.audiosector.com
Old 22nd October 2009, 03:54 PM   #15
Thanks peter.
Old 27th November 2009, 03:43 PM   #16
I'd like to present here an example how to implement those boards in a stand alone PS.
I like to use 2 x 3 aluminum tubing for all my projects now. It simplifies chassis building as the main body of an enclosure consist of a single tube section cut to the required size, the end panels are really optional.
To reduce the amount of external screws, I'm using sub-plate to mount regulator board. The LM317 is installed on a sub-plate as well, as attaching screws inside the tube would be vary hard.
Transformer is mounted on a proto board, with p2p wiring. Please note that the Earth terminal from power entry module is soldered to a copper foil underneath one of the stand offs to ground the chassis.
Additional Burns potentiometer is used to set the output between 9-13V
www.audiosector.com
Old 27th November 2009, 04:03 PM   #17
Such assembly slides into the tubing and I'm only using 4 screws to secure it (additional soft pad on top of transformer prevents any movement).
This particular PS is intended for use with field coil of Fertin driver.
One pair of binding posts is for batteries attachment (in case batteries are not use, additional capacitor can be installed there), the other for driver connection. The toggle switch disconnects power to the driver, the potentiometer allows fine tuning of voltage output.
www.audiosector.com
Old 27th November 2009, 04:20 PM   #18
A piece of hard foam can be used to cover the opening.
www.audiosector.com
Old 28th November 2009, 08:54 PM   #19
sandbasser's Avatar
Peter -
Your work is brilliant. Very creative use of materials and parts.
If you wouldn't mind, I have a couple of questions...
1) why do you cut the square piece out of the middle of the board to mount the regulator? Aren't the small round holes in the middle of the resistor layouts for that???
2) do you make the board standoffs yourself??? or wwhere you you get them (p/n please) ???- they almost look like bronze flanged bushings.
3) finally is the brand of the large 4700 uF cap ???
Thanks,
- Ray
- Ray
Old 28th November 2009, 09:37 PM   #20
Ray, Thanks for the comments.
The round hole is too small for the screw head to go through, initially it was intended to improve air flow around resistor or heatsink, it can be also used as a mounting hole.
But now when you mentioned it, enlarging it would work fine. The cut out allows me to see better how regulator aligns on a mica pad, but it's not really critical.
The standoffs are indeed bronze flanged bushings, I bought them at local surplus outlet.
The cap is Roederstein (ROE); it's NOS but surprisingly good, in some applications better than BG.
www.audiosector.com
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 24th April 2011 12:48 AM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 06:10 PM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 03:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 02:30 PM
Page generated in 0.11823 seconds (76.96% PHP - 23.04% MySQL) with 11 queries
