Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 8th October 2010, 03:05 AM   #51
wlowes is offline wlowes  Canada
wlowes's Avatar
Default modification questions
I am a very happy user of your usb dac for quite a while. It is very good.
I am interested in experimenting with USB to a tda1541a board. Am I correct that I should be able to tap into the signal from pins 1,2&3 of the 1543 on your board, and drive the I2S inputs to a 1541 on a separate board?
Old 8th October 2010, 03:07 AM   #52
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Audiosector USB DAC Send a message via AIM to Peter Daniel
Yes, that's correct, plus ground.
To order kits contact me through forum mail.
Old 8th October 2010, 03:25 AM   #53
wlowes's Avatar
For those that like to experiment, I suggest experamenting with Sanyo Os-Cons SEPC caps with this DAC. I used the 16SEPC150MD in place of the 1000uf blackgate NX which I had borrowed for another project and some Panasonic 5600uf caps in place of the bg std. Your opinion may vary but to me it took a leap forward. Sound stage bigger, 3d, and precise.
The DAC is excellent as specified. This tweek may be an interesting alternative to some.
Old 8th October 2010, 09:15 PM   #54
matt J is offline matt J  England
Hi Peter, I only have Toslink available as digital out, is it possible to rig something up?
Old 9th October 2010, 04:48 AM   #55
wlowes's Avatar
Awsome!! Thank you. I missed the ground.
This has allowed me to combine three amazing innovators in this hobby. Peter Danial gainclone, +USB DAC + CICSPlay + Lampizator TDA1541. Things are sounding good! Thanks again!
BTW.. put os-con sepc series caps at the pcm2706 with great effect. I think it takes it to a different level.
Old 9th October 2010, 05:04 AM   #56
le´flu is offline le´flu  Germany
Hello Peter,
I am putting together a DAC based on PCM1794. If it suounds better than my modified TDA1543 I will let everybody know.
any news you would let us know? I´m still using your DAC and upgrades are
always welcome ;-)
By the way, what (brand) are those multi-pin connectors (black ones) between
psu and main PCB?
Greetings ulf
Old 9th October 2010, 05:55 AM   #57
Those are Switchcraft: Digi-Key - SC1237-ND (Manufacturer - 4282-5SG-300) I still didn't the put the new DAC together
Using Toslink for input is not a problem, here's how it can be done:
Old 18th October 2010, 03:20 AM   #58
coolrock is offline coolrock  India
Default dac with optical input
I want the dac with optical input as my cdp and sound card have only optical out.Will it be as good as coaxial or will there be any difference in sound quality.
Old 5th November 2010, 02:38 PM   #59
nightanole is offline nightanole  United States
How do i buy the usb dac or even get any info on the new 1794 version?
Old 5th November 2010, 09:35 PM   #60
I'm out of USB DACs, (only SPDIF version is available) and I didn't touch 1794 yet.
Audiosector USB DACHide this!Advertise here!
Fs: Audiosector Nos Dac r8833 Swap Meet 6 14th February 2009 02:59 AM
Chipamp PS audiosector PS Ted205 Chip Amps 5 11th August 2008 01:59 PM
AudioSector NOS DAC $225 obo nodiak Swap Meet 2 8th November 2007 05:10 PM
Audiosector NOS Dac Darrell Morgan Digital Source 7 8th August 2007 02:55 AM
audiosector dac karma Chip Amps 3 7th December 2005 01:04 AM
