Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 25th December 2014, 12:49 PM   #11
pmchoong is offline pmchoong  Malaysia
pmchoong's Avatar
Originally Posted by Peter Daniel View Post
So you are using one board per channel for unbalanced operation, just the input is XLR, right?
In that case positive input to the amp goes to pad marked IN+, ground to SG and IIRC the pad marked as IN- should be grounded too.
GND pad is for connecting ground reference from power supply board. Also, ground from PS goes directly to speaker negative connector.
Some additional; info can be found here: Group buy: Peter Daniels AJ-X pcb GroupBuy2 - diyAudio
Merry Christmas to you and thanks for the reply.
Yes, one board per channel using just the XLR input.
Please see the attached drawing. Is this what you mean by grounding the IN- as well?
Old 25th December 2014, 04:31 PM   #12
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Support Send a message via AIM to Peter Daniel
Merry Christmas and yes, that's what I meant.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 27th December 2014, 03:12 PM   #13
pmchoong's Avatar
I tried that but no sound is coming out of the amp. So I dissolder the connection and go back to the original setting.
SupportHide this!Advertise here!
Support - Apex Jr Variac Apex Jr 26 30th April 2018 02:35 PM
Support Variac Elektor 0 22nd August 2009 09:16 AM
HP support DragonMaster Everything Else 3 31st August 2005 04:52 PM
