Commercial Gainclone kit- building instructions - Page 91 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 14th November 2009, 08:21 PM   #901
LucasAdamson's Avatar
Ah...then I have a completely different idea...are your chips the insulated type or naked? National make both. If naked it is possible that you need to insulate them.
Lucas
Old 14th November 2009, 08:24 PM   #902
tiglitosa's Avatar
Send a message via MSN to tiglitosa
Its the LM 3875 TF all black and i think its insulated type.
Old 14th November 2009, 10:12 PM   #903
tiglitosa's Avatar
here are two pics one of the guts and one of the housing if they help
Nick
Old 15th November 2009, 08:59 AM   #904
tiglitosa's Avatar
since its Sunday i cannot get caps as peter suggested but i tried to turn off all apliances that might produced interference. Wifi, wilress phones etc.
Nothing changed.
i connected a source and when the music started this loud audible mors code stoped. The music was more cleared when i turned the pot to louder. There were some static in the music thous but the noise did not exist. It appeared again in the time between the songs or when a song had a pause.
I have also connected a filer in the input of the psu to be on the safe side.
Any ideas?
Old 15th November 2009, 11:27 AM   #905
tiglitosa's Avatar
Ok that was it !!!
its idiotic !! I should have notice that earlier. The speaker had burned its crossover and thus produced this sound !!!! it was a small wooden 2 way jcv 6ohm 40w speaker that could not handle the power. I tried it with a bookself 80w 8 ohms crystal audio and voila!!!
Though some clipping occurs but i think with bigger speaker i will not have any problems.
soon some finished pics !!
thank you
Nick
Old 15th November 2009, 01:51 PM   #906
could the damaged speaker have been overloading the chipamp and the protection systems were intermittantly switching the chipamp to some safe mode?
How is the TF chip mounted to the heatsink?
Where does that cable go?
Is the TF thermally coupled to the heatsink or is it mounted dry?
How does the heat get out of the TF?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 15th November 2009, 01:57 PM   #907
tiglitosa's Avatar
Perhaps i dont really know !
It is mounted through a bolt. Actually the bottom of the amp is the heatsink (2cm thick aluminum plate).
its going to the chassis ground on the amp board
I use Zalman thermal greace used for computer chips.
the Aluminum board stays pretty cool if thats what you mean. The tf is attached to the heatsink throug a copper leaf.
Nick
Old 15th November 2009, 02:29 PM   #908
your answers do not look like the pic (superb quality and focus).
regards Andrew T.
Old 15th November 2009, 03:07 PM   #909
tiglitosa's Avatar
Sorry i lost you Why my answers does not look like the pic? in which case?
thank you
Nick
Old 15th November 2009, 03:24 PM   #910
what is between the chassis base plate and the TF mounting face?
What you listed is not what I can see in the pic.
regards Andrew T.
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 09:07 AM
Copyright 1999-2017 diyAudio
