Commercial Gainclone kit- building instructions Commercial Gainclone kit- building instructions - Page 71 - diyAudio
Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 19th May 2009, 08:19 PM   #701
kele1975 is offline kele1975  Bosnia and Herzegovina
I think 35VAC/50VDC is way too much.
LM3875 can handle (in theory) 84VDC(42-0-42).
Old 19th May 2009, 08:27 PM   #702
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
Originally posted by roger_lew
and I figure my rail voltages will be about 50V (35 x 1.4).
Those would be way too high, you shouldn't be exceeding 40V on rails.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 19th May 2009, 08:38 PM   #703
roger_lew is offline roger_lew  United States
roger_lew's Avatar
Thanks, that makes sense. I was thinking the 84 rating was from 0 to the rail.
Does anyone know if a regulated center tap power supply suitable for gainclone use?
Old 19th May 2009, 09:00 PM   #704
Check this thread for regulated supply option: http://www.diyaudio.com/forums/showt...106&highlight=
However, don't take seriously the hype that it elevates the chipamp to a league of it's own.
www.audiosector.com
Old 19th May 2009, 11:58 PM   #705
roger_lew's Avatar
Thanks again Peter. That thread was helpful (despite the hype ).
I suppose the easiest way to go about this is to give up on dual mono and have a single PSU power both channels. That way I can use each transformer to power each rail of a regulated power supply (with center tap wave rectifier).
Building a dedicated regulated supply for each channel isn't straight forward enough for me to attempt given my very limited experience. Since I have center tapped transformers building one seems to require a 5 amp negative voltage regulator (complementary ICs to the LM338) which don't seem to be commonly available.
Does this plan seem reasonable?
Roger
Old 20th May 2009, 12:23 AM   #706
... one seems to require a 5 amp negative voltage regulator (complementary ICs to the LM338) which don't seem to be commonly available.
You don't need that, both positive and negative rails are powered from a (positive) LM388 regulator: http://www.diyaudio.com/forums/attac...amp=1114473823
www.audiosector.com
Old 20th May 2009, 12:39 AM   #707
roger_lew's Avatar
Right, we are on the same page. If I build a single power supply for both channels I don' t need a negative voltage regulator. I can use two LM338s.
But if I wanted to go full mono and build a regulated dual channel supply with a single center tapped transformer I would need a high current negative voltage regulator.
http://www.diyaudio.com/forums/showt...94#post1616994
http://www.diyaudio.com/forums/showt...73#post1617073
Old 20th May 2009, 10:19 AM   #708
If you use half of each transformer, you can build a positive regulator on each.
Couple the two +ve supplies together to create a dual polarity supply.
What a waste of resources.
If these transformers are so important to you then buy amplifiers that suit +-50Vdc supplies.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 20th May 2009, 03:38 PM   #709
You can use one (complete) transformer per rail, if you wire them as in attached schematic. This setup will also allow positive regulator in a negative rail.
Such supply would be powering both channels.
If you need dual mono configuration, with separate supply for each channel, you need to source suitable negative regulators.
www.audiosector.com
Old 20th May 2009, 06:07 PM   #710
roger_lew's Avatar
Andrew,
Thanks for the advice. I'm dead set on building a gainclone from a audiosector kit due to their simplicity and the detail Peter has put into the instructions. Whether I use these transformers with a regulated PS or buy toroids is still something I'm tolling over. I might just save these for a more suitable project down the road.
Peter,
I placed an order for a premium kit. Thanks for the schematic. We are still on the same page.
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
Copyright ©1999-2017 diyAudio
