Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 19th March 2009, 12:55 AM   #531
LucasAdamson is offline LucasAdamson  United Kingdom
LucasAdamson's Avatar
Originally posted by Peter Daniel
You may try Zobel, checking the small cap wouldn't hurt either. As to Zobel, it is 2R7 and 0.1uF.
Can anybody explain or point me to info on installing a Zobel network, and what I'm trying to achieve with it? Will it make my amp more mediocre? That would be a shame...
Many thanks
Lucas
Old 19th March 2009, 01:00 AM   #532
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
Well, if you check this thread, it may make you believe that the amp needs a Zobel: http://www.diyaudio.com/forums/showt...039&highlight=
However, in well integrated systems, Zobel can actually degrade the sound, ask Nuuk
Originally posted by ppapcro
Hi Peter
Would there be any problem (in terms of grounding/hum) with a
3-chassis setup like this:
center- patek style power star ground layout for amp boards
left- 300 VA TR into rec. brd. then out umbil. to L amp inputs
right- 300 VA TR into rec. brd. then out umbil. to R amp inputs
with the ground wires from L & R psu's connecting to the thick copper star joining the amp boards
If you run separate PS, there is no need to connect both channel grounds as in Patek amp; run them separately all the way. Here's an example of such amp.
To order kits contact me through forum mail.
Old 20th March 2009, 02:46 AM   #533
kierownik is offline kierownik  United States
kierownik's Avatar
Hi
which setup of the lm4780 kit is sonically better, paralleled or bridged?
I'd like to use it as a sub woofer amp. Should I use bigger caps or implement the snubber?
Old 20th March 2009, 03:09 AM   #534
In my experience, bridged is better, but you need a balanced source and be sure that speaker impedance does not go below 8 ohm. Otherwise you have no choice but to go paralleled.
Snuber is recommended only with big caps, so go with big caps first and then try a snubber.
Old 21st March 2009, 02:18 PM   #535
KASUMI is offline KASUMI  United Kingdom
Default Earthing again
Hi
I've built a premium kit to be used with Oris horns boosting a bass driver,thanks Peter for the quick delivery.
The amp is in a mono config feeding a crossover for the horns.I'm getting a low level hum.
I have the power earth connected to the chassis.What should be earthed in this arrangement.Hopefully the pic should show the connections
Rob
Old 22nd March 2009, 10:27 AM   #536
Quick edit the output of the crossover feeds the chipamp and + and - is the input,Output is from pin 2 of the pot and - on the board.have tried various earthing arrangements.
Rob
Old 22nd March 2009, 10:44 AM   #537
R.I.P.
the secondaries look like insulated solid core.
If they are, replace with longer flexible stranded, still twisted.
Now you may have enough lead flexibility to rotate your toroid on it's mounting bolt. This may affect the hum by pointing the worst field spikes away from the sensitive circuits. Rotate to minimise hum and then consider whether you need/wish to shorten the flexy leads.
The mains Safety Earth should be shortened and bolted next to the incoming mains location.
The ground attached to that existing bolt can stay where it is.
It might be worth trying a wire link or a cap link from the metal pot support back to the Safety Earth plate.
How warm is it going to get inside that insulated box when the lid is secured? My guess is that everything inside will slowly cook even with just 5W of losses shared among all those components. Maybe 10 to 15W of losses, try measuring the quiescent consumption with no load.
regards Andrew T.
Old 22nd March 2009, 03:09 PM   #538
cyxg is offline cyxg  Australia
hi,peter
I am very interest in you amp. I want to buy a 3875 kit for my ProAc 2.5.
please give me suggestion.
thanks.
Old 22nd March 2009, 03:09 PM   #539
And between V- and PG- (black probe on PG)
If we measure approx. +/- 20V (positive will be lower because of LED) we are ready to connect amp boards.
Please note that voltages are much lower than expected beacuse of lack of smoothing caps.
If you have 10uF caps installed on rectifiers board both voltages would exceed 30V DC
hi,peter
thanks.
Old 22nd March 2009, 09:49 PM   #540
Thanks AndrewT,the amps dont get even remotely warm the bass drivers are quite efficient.
Waiting on some stepped attenuators before I can mount everything properley,interesting re the box layout I hadn't really thought of that.
I'm wondering as its a wooden box should the signal earth from the crossover and SG and CHG on the chipamp be connected to the power supply earth or just connected together ?
Rob
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
