Go Back   Home > Forums > Commercial Sector > Vendor Forums > Audio Sector
Audio Sector Kits & PC boards from AudioSector
Old 31st January 2009, 08:59 PM   #481
raypalmer's Avatar
Default Re: Fuse blow
Originally posted by canadino
My fuse blow after I connected the amp boards. When I taste the rectifier board was all ok.
What's going wrong?
There's no accounting for taste...
Sounds like you've got P's and V's mixed up?
Wherever you go there you are.
Old 31st January 2009, 09:24 PM   #482
raypalmer's Avatar
Here's a Q. Whenever my TV is switched on my amp hums. I did the necessary CSI work and determined it's not sending noise through the mains. The hum is induced through the interconnects. Evidently it's passing through my Wakonda into the amp which is sensitive to it. The LK100 I've replaced wasn't vulnerable to this.
I'm guessing the TV has a poor output stage and generates noise? Would this be through the input ground? A coworker suggested the tv may produce an unnecessarily high output voltage....
Thoughts?
Old 1st February 2009, 08:46 PM   #483
I taste 9v batteries, was never macho enough to taste power supplies
Wish I'd studied this stuff with as much interest 30 years ago!
Old 1st February 2009, 09:55 PM   #484
Thoughts?
Ray-
My guess would be ground loop problems. Most 'pro' audio/studio equipment has 'ground lift' switches fitted to avoid such problems.
I ran into a similar thing when I was trying to mate up a networked laptop to a stereo receiver. (and didn't solve the problem completely, so abandoned that idea for the time being).
Cheers
John
Old 2nd February 2009, 07:53 AM   #485
AndrewT is online now AndrewT  Scotland
But be careful.
Some dangerous "ground lift" switches break the Safety Ground connection.
The "ground lift" switch should bypass the Disconnecting Network between the Safety Earth and the Audio Ground.
This arrangement is safe in either position.
Old 2nd February 2009, 08:37 AM   #486
audio1st's Avatar
Hi Ray, you may need to isolate the RCA's from the chassis, (can't see isolation in your pic's).
I didn't mention it earlier as you had no problem. It is the norm to have isolating washers on the RCA's..
Old 2nd February 2009, 11:18 AM   #487
Default Caps
I don't understand very well the difference between: Ci caps, I/P caps and coupling caps. Where to install them?
Goodbye.
Old 2nd February 2009, 12:03 PM   #488
the input cap in series with the input connection is often called all three of these names and also referred to as the DC blocking cap and High Pass filter cap.
Ci = a cap on the input.
I/P cap = input cap.
Coupling cap = a cap to couple two stages.
DC blocking cap = a cap to block DC that might exist between two stages.
High Pass Filter cap = the series cap before Rin to ground that creates a 6dB/Octave filter that rolls off the low frequency and allows the higher frequencies to pass.
They are all the same.
Old 3rd February 2009, 09:36 PM   #489
kierownik's Avatar
Hi guys
Do you recommend smaller value Ci cap if the channel is going to drive mid/tweeter only and higher value for bass? (like in Peter's 4 channel amp) Or should I just stick with 1500 uF only?(LM4780 amp board in parallel)
Old 3rd February 2009, 09:52 PM   #490
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
And which cap do you mean by Ci?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 365 4th October 2011 08:19 AM
Page generated in 0.24581 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
