Go Back   Home > Forums > > >
Audio Sector Kits & PC boards from AudioSector
Old 17th November 2008, 03:01 PM   #311
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Commercial Gainclone kit- building instructions Send a message via AIM to Peter Daniel
I would say 100VA would be minimum, and I normally use 300VA toroids. As to the voltage, 15-25V AC (dual secondaries or centertapped)
To order kits contact me through forum mail.
Old 25th November 2008, 09:48 PM   #312
bestbier is offline bestbier  Netherlands
Just received your kit today. It's all soldered already. Now the transformer (ILP)
Old 30th November 2008, 10:58 PM   #313
I thought it may be a good idea to post a link here to a place in Poland that produces affordable and very good transformers: http://www.toroidy.pl/index.php?page...emart&Itemid=2
Ask for a special audio version:
TS300VA PRI:115V SEC:2x22V for AUDIO:
- secondary at the core with 50% higher diameter, single wire (1,8mm)
I used such transformer in my best amp yet: http://www.diyaudio.com/forums/showt...609&highlight= althought it was amorphous core, which I hear is not available any longer.
Old 30th November 2008, 11:08 PM   #314
afunkymonk is offline afunkymonk  Hong Kong
Originally posted by Peter Daniel
Are you sure you didn't mixed up resistors on amp PCBs?
The values should be according to schematic here: http://www.diyaudio.com/forums/attac...amp=1210693738
I have checked this and it was not the problem. I'm a bit stuck now. I'm considering making up the stereo config as in your pictures. If that works, then I will work backwards (or just leave it as it is...) The ony non standard bit of kit is the LED and RLED which I salvaged from a PC. Can this be jumpered or left out to eliminate it?
Matt
Old 30th November 2008, 11:11 PM   #315
Don't jumper, just leave out.
Old 1st December 2008, 11:26 AM   #316
samoloko is offline samoloko  Bulgaria
Hi Peter
do you think that Toroidy transformers build for audio are better than Plitron of such type
Old 1st December 2008, 03:56 PM   #317
If they were with amorphous core, they would be better, otherwise, they are certainly comparable.
BTW, I also used those tranformers in my Zv9: http://www.diyaudio.com/forums/showt...590&highlight=
Old 1st December 2008, 07:10 PM   #318
thx Peter
very good hint
Is that transformer build for audio use - It Is not encapsulated
I am very sensitive to noise - hate mechanical, buzz that some transformers make
have somebody used www.amplimo.com transformers
are they In relation with Plitron
Old 2nd December 2008, 05:40 PM   #319
mikejennens is offline mikejennens  United States
This speaker DIY thing, it's pretty addicting!
mikejennens's Avatar
Default Subwoofer on my 3875 amp
I just finished a chipamp.com LM3875. Thanks for the coaching and guidance Peter. I'm running a pair of FR Tangband speakers (3CR-Ti on the PE speaker projects page). I'd like to add a sub to get a little more bass. What is the best way to connect the sub to my amp? Is running the sub in parallel with my speakers, off the speaker jacks, the right way?
Thanks.
Mike
Jolida SJ502A, Squeezebox Touch, Paul Carmody's Sunflowers, Jeff Bagby's Continuums; Planet 10 HiFi's MarkAudio A 7.3 Frugalhorns and MarkAudio CHP-70s, Nola Brio Clones with a Voxel Sub and a bunch of others...
Old 3rd December 2008, 02:12 PM   #320
Off the speaker jacks for a sub will work.
Commercial Gainclone kit- building instructionsHide this!Advertise here!
Commercial complete Gainclone kit for a beginner? gychang Chip Amps 371 20th January 2015 08:07 AM
